Hi -
I'm hoping someone knowledgable with TFT flat panels could provide me with some troubleshooting tips. I am in the process of replacing a defective LCD panel from a piece of test equipment EOL 20+yrs. I've replaced the panel in this same unit in the past using a laptop screen from a scrapped unit. The display was an old Hitachi panel and it gave me no problems, it worked well.
Well that display also went belly up so now I'm trying to shoe horn an obsolete Sharp LQ10DS05 800x600 SVGA TFT display into the unit and its giving me problems. The display was unused NOS and dirt cheap (why I bought it). Unfortunately the datasheet is nowhere to be found, so I just pushed forward as the electrical interface pin out is the same from other Sharp displays in the '95 time frame.
The issue is the display is tearing while displaying graphics images (see pictures). However, while displaying DOS text type video it seems OK. I know I have some vertical timing tweaks that need attention, but I am wondering if the tearing is related to timing or if it is due to defective panel hardware. I could use some direction as to how to verify whether the panel is electrically defective or not. Unfortunately, I have no other source of video other than the piece of test equipment that I am restoring. I'm leaning on the display being defective.
Any advice would be appreciated.
