This looks like the primary switching FET is shorted. It often happens when they fail that all three terminals get shorted together and then high voltage passes through the transformer (very low resistance), through the shorted MOSFET and blows up the current sense resistor (0.15Ω) and often also the gate drive circuit - some resistors, maybe a diode and probably the UC3843 chip too.
UC3843 is a very common and well known controller, you can easily find datasheets, application notes and any other information. Also replacement chips, if necessary. This PSU should be repairable, but there are many components which may have been exposed to high voltage and destroyed, and failing to identify and repair just a few could lead to another bang and wasted time.
Don't try to turn it on to avoid further damage. Make sure all caps are discharged and see if you can detect a short between the high voltage rails on the primary with DMM. Remove the 1.5Ω resistor - it's wrong value anyway. With this removed, test for drain-source short in the MOSFET. If it appears shorted in absence of the 0.15/1.5 resistor, it's 99% sure the MOSFET is shorted internally - desolder it and test out of circuit. It shouldn't have a short between gate and source, and if you short gate to source, it shouldn't conduct from drain to source.
If bad FET is confirmed, test all resistors on the UC3843 board. Check for internal shorts in UC3843, like FET drive pin to GND or VCC.
