Author Topic: Changing the output RF power of nRF24l01+ PA LNA module possible???  (Read 366 times)
Offline DhanushkaTopic starter
  • Country: lk
I m looking for some way to reduce the RF output power of the nrf24l01+ PA LNA module with 2dBi antenna for a project work. I m not coming from communication background. So, it is please that someone can explain this with proofs.
It is possible to change the RF power of the nrf24l01+ chip. But I m wondering whether it can be done for the module with power amplifier and antenna. This is possible if the RF amplifier change the output power under the input power. So, I need to know about the power amplifier is working as this or whatever the input power the output power the output power in same 20dB state. Power amp datasheet is so confusing. That's why I m asking a help of you.
Thanks
