No not just any enclosure. This one has a polycarb window on the front:
https://imgur.com/a/QS49B
Otherwise it's just a bog-standard indoor NEMA 1 box. The front cover lifts off (with a simple release at the bottom)--no screws or such.
The label in the photo is on the inside of the cover which may be listed as an accessory cover, don't know.
It's difficult to find a GE distributor in the US that carry small enclosures. Most carry distribution switchgear stuff.
Any help locating something equivalent that isn't a NEMA5000
would be greatly appreciated.
Thanks.
I agree with dave_k, looks like a standard CLXE1A enclosure with a field-made hole cut in it. Based on pictures I've found of the CLXE1A enclosure online, it appears that the clear plastic is even held on via field-added screws.
The givaways are: The rough, uneven cut of the hole, the pencil markings for the centers of the bolt holes, and the choice of fasteners to hold the plastic into the enclosure. A stock enclosure would have not such a rough cut, The fasteners would likely be stamped in at the factory (i.e. bolt in metal part, nuts on the inside), etc.
I could point you toward various enclosures with windows in them though if you need.... what size/type/etc?
