I'm powering an ARM MCU (TI/Luminary LQFP thingie, among some other things) from 9V - 12V (somewhere around there) and I'm wondering what the best way is to do this. My first thought was to simply use an LM2675-3.3 switcher to simply bring that down to 3.3V. But then I'm starting to think I might want +5V on the board as well.
Is using an LM2675-5.0 for the +5V and then an LDO to 3.3V a good idea for this? If so, any LDO you can recommend? If I didn't want 5V, would there still be a point in using an LDO for cleaner power for the MCU?
