Author Topic: What do you use for ESD protection today?  (Read 712 times)
Offline Gibson486Topic starter
« on: June 27, 2018, 02:07:54 am »
Do you use gold old one diode to VDD and one to GND? Do you use a TVS? A zener? Do you use a chip that combines multiple different types?
Offline T3sl4co1l
    • Seven Transistor Labs
Re: What do you use for ESD protection today?
« Reply #1 on: June 27, 2018, 02:49:23 am »
Yes.
There is no single ESD solution, because there are many situations and requirements.  Clamp diodes are fine for logic signals, but bad for:
- Inputs with wide voltage range, e.g. analog, RS-422, CAN
- Where the signal must not be loaded by a deenergized supply (various bussed and low-power systems)
- Where the clamp voltage is different from the supply voltage (another way to say the above, really)
- Low leakage applications (give or take diode type and requirement -- schottky are fine for logic, but often unsuitable just for general analog signals; junction diodes are unsuitable for very low leakage analog signals)
Seven Transistor Labs, LLC
