Hello, I have a TP5100 charger and want to charge a 2S battery pack to lower voltage to extend the lifespan of the batteries.
I've seen some people on this forum suggest adding a schottky diode in series with the charger to introduce a voltage drop in the charging voltage thus lowering the voltage among the batteries. I'm wondering if that would work since I don't understand how would the charger be able to sense the battery voltage if there is a diode in the path? Thanks for the help.
Here is the schematic of how I would wire it all up (there's also under-voltage protection before the load):
EDIT: I just noticed I drew some wires wrong, fixed now
