Author Topic: Charging LifePO4 battery with CC power supply?  (Read 1299 times)
Offline drummerdimitriTopic starter
  • Country: lb
« on: November 26, 2021, 02:18:18 pm »
Would it be possible to use a Constant Current DC power supply with an adjustable output voltage to charge a 12V LifePO4 battery with a capacity of 120 Ah?
It is my understanding that these cells should be charged via CC and then CV which is exactly what this power supply would be doing with a max charge rate of 60A or (0.5C) and can be set to a maximum of 13.6V (99% SOC for this battery).
Should I try doing this or should I invest in a dedicated 2 or 3 stage battery charger? I will be using it to power a 1200W pure sinewave inverter with a bypass function when AC power is present as it does not come with an integrated battery charger.
Seems safe to me but I would like to hear from people with more experience.
  • Country: lb
Re: Charging LifePO4 battery with CC power supply?
« Reply #1 on: November 29, 2021, 11:14:19 pm »
BUMP!
Offline thm_w
  • Non-expert
« Reply #2 on: November 30, 2021, 11:10:51 pm »
Yes it will work. May want to take precautions in case of backfeed, as it could destroy some PSUs.
We are talking about a 12V battery with built in BMS in case of over/under temperature and voltage right?
https://www.youtube.com/watch?v=-c6A1THDaeU (psu shown)
https://www.youtube.com/user/errolprowse
  • Country: lb
« Reply #3 on: November 30, 2021, 11:34:39 pm »
Yes exactly, the battery is a 12V (4s) configuration with an external BMS.
I've actually gave this setup a try and it works brilliantly and no problems with backfeed as I initially purchased this PSU to charge my 12V supercapacitor bank from 0V.
