Author Topic: Ideas to activate device after mounting it the ground  (Read 646 times)
Offline mrburnzieTopic starter
  • Country: cs
« on: April 07, 2020, 02:21:47 pm »
I have a product that is mounted in the ground. It is using sensors which need to be calibrated after put into the ground. It uses LoRaWAN to communicate. It is very low power device. The case is fully sealed (IP rating).
My concern is after it gets assembled, I don't want to turn it on, because it will stay in stock for a while which will drain the battery, so the solution is to turn it on just before it gets mounted.
Because the case is sealed, what are the methods to turn on the device?  ???
What are the easiest methods to solve something like this?
Thanks!
« Last Edit: April 07, 2020, 02:26:51 pm by mrburnzie »
"Talk is cheap, show me the code"
Anyone need of freelance software/hardware developer, hit me up!
Offline max_torque
    • bitdynamics
Re: Ideas to activate device after mounting it the ground
« Reply #1 on: April 07, 2020, 02:32:18 pm »
I've seen people use a magnetic read switch to turn on power to a device when it's needed, where you place a magnet in the correct spot on the outside of the device to pull the read switch contacts together so the unit gets power. I've also seen orientation switching, where a ball bearings falls across contacts when the unit is the correct way up, and you store it "up-side-down"........
The following users thanked this post: Smokey
  • Country: cs
« Reply #2 on: April 07, 2020, 02:33:24 pm »
Yes, I was thinking of the magnet too, but the upside down thing I didn't! Not a bad solution!
Offline coromonadalix
« Reply #3 on: April 07, 2020, 06:47:17 pm »
same thing  for a magnet    you have some door alarms switchs who could do the job ???
Offline max_torque
    • bitdynamics
« Reply #4 on: April 07, 2020, 07:17:06 pm »
Search for "rolling ball tilt switch" or variations on that theme!
The following users thanked this post: Smokey, mrburnzie
« Reply #5 on: April 07, 2020, 10:03:41 pm »
mercury switch ??
