I'm working on a power supply project using a few cheap ebay parts and I found a problem that is stumping me.
Using a $2 dollar panel voltmeter with 3 wires. Common ground with separate power and sense wires.
And a $2 dollar 3 amp PWM module.
I'm making a little power box that I can plug in any of my wall warts and make it adjustable.
Anyhow, I was whacking my brain against the wall
trying to figure out why this simple circuit was not working correctly. It turns out that my PWM module is switching the LOW side!
My panel meter is not happy with this configuration. I can hook up all the meter wires to output and it works OK but the meter shuts off under 3 volts. My PWM control goes down to 1.2 volts and this meter is capable of reading 1.2 volts.
Is there a trick to wire this up and make it work as intended?
Or is this low side switching with a common ground meter pooping on my parade?
