Author Topic: cheap IR thermometers  (Read 2321 times)
Offline JBealeTopic starter
« on: March 18, 2016, 08:52:06 pm »
I see that you can now buy a handheld IR thermometer for under $10 on Amazon, for example:
http://www.amazon.com/Digital-Infrared-Thermometer-Temperature-Pyrometer/dp/B013Z8NHCG
I bought a slightly more expensive $18 version which works perfectly well. Haven't taken it apart yet but I can see they are using a dime-sized IR fresnel lens to achieve the 12:1 ratio focusing onto some internal thermal sensor.
Does anyone know if the thermal sensing module by itself (without the laser pointer, LCD display etc.) is available, for example with a serial output?  I would think such a thing should exist, but I haven't seen it anywhere.
Or maybe what I want is the TI TMP007 breakout board like https://www.adafruit.com/products/2023 plus an IR lens from http://www.glolab.com/pirparts/pirparts.html ?
Offline TonyD
Re: cheap IR thermometers
« Reply #1 on: March 26, 2016, 12:29:15 am »
I got a similar model a few years back.
For what I remember it just had a simple thermopile sensor with analogue output.
Any particular reason you need one with a serial output? (other than its just a cool thing to try out)
Offline bhalakiya
  • Country: in
« Reply #2 on: April 09, 2016, 05:31:45 pm »
What about MLX90614!!!
It has both interfaces PWM(Analog) as well as I2C
Offline Raj
  • Country: in
  • Self taught, experimenter, noob(ish)
« Reply #3 on: May 13, 2016, 07:20:31 am »
I am also working on same stuff... (i'll be using mlx90614)(Just having a display dilemma ,can't decide what display to use with atmega8 qfn just can't find a display small enough)
btw here's some suggestions
mlx90614 for single point
mlx90621 for camera
