Author Topic: How to set and measure the loop Response of a Flyback using the Bode 100  (Read 741 times)
Offline rbola35618Topic starter
In this video, I show how to set and measure the loop response of a discontinuous Flyback converter. I show how to validate the spice model, how to use Zero-Pole canceling to set the loop. I also show how to used the Bode 100 to measure the transfer function of the Output Filter, the Error Amp, and then take the Open Loop response. Questions and comments can be sent to rbola35618@aol.com or posted here on YouTube.
Offline gae_31
Re: How to set and measure the loop Response of a Flyback using the Bode 100
« Reply #1 on: January 19, 2021, 05:20:00 pm »
Would be great if you could show the difference in frequency response between the Bode 100 and the Cleverscope.
