Author Topic: uRuler Gerbers  (Read 4774 times)
Online EEVblogTopic starter
uRuler Gerbers
« on: September 17, 2012, 01:46:11 am »
For those who have asked, here are the gerbers.
http://www.eevblog.com/projects/uruler/
Dave.
Offline andyturk
Re: uRuler Gerbers
« Reply #1 on: September 17, 2012, 05:53:31 am »
Very cool. Thanks!
But using a proprietary file format (.rar) for open source project files? Hmmm. :o
Re: uRuler Gerbers
« Reply #2 on: September 17, 2012, 06:04:16 am »
Hadn't given it a thought.
What should I be using? (Windoze)
Dave.
Offline cwalex
Re: uRuler Gerbers
« Reply #3 on: September 17, 2012, 06:24:01 am »
Very cool. Thanks!
You can use 7zip for rar. It's open source, has windows and linux support.
Are you planning on selling these Dave? I'd like to buy one, looks awesome.
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: uRuler Gerbers
« Reply #4 on: September 17, 2012, 08:19:45 am »
One minor omission - mil eqiuvalents of the 0.1mm increments of drill sizes - don't know how common it is but PCAD shows drill sizes in mils if in imperial mode.
..and if you want a real luxury (expensive) version, on the other side have a matrix of all the different resist and silkscreen colours.
Zip is much more commonly used, and supported directly by more recent Windoze versions, and universally accepted by PCB manufacturers.
I don't give a crap about proprietoriness, just ease of use and ubiquity.
Day Job: Mostly LEDs
Offline Psi
Re: uRuler Gerbers
« Reply #5 on: September 17, 2012, 09:04:17 am »
I really like those holes on the ends, makes finding the right size hole for any TH component really easy.
Offline samgab
Re: uRuler Gerbers
« Reply #6 on: September 17, 2012, 09:25:28 am »
These are so freakin' cool. Cheers for this Dave. Now, how to get some made in NZ...  ???
Offline Psi
Re: uRuler Gerbers
« Reply #7 on: September 17, 2012, 11:43:19 am »
Dave's ones were made in NZ, at pcbzone in Auckland
Re: uRuler Gerbers
« Reply #8 on: September 17, 2012, 11:44:38 am »
Yeah, had to leave something out in the end. Only had a mil->mm table.
Drill sizes are mostly done in mm anyway.
That would be nice. These were unfortunately a last minute rush job. Circuit Labs only had time to do a single sided run, and no gold plate, so it's only bare copper. Ideally I wanted metric one side, imperial the other etc.
The bigger wider 30cm rulers fit a lot more info and clearer text, but I liked the idea of compact 6" rule. Wider than a standard 6" rule though, so expanded to 7"
Should be very durable using Circuit Labs photo emulsion component overlay technique.
Dave.
« Last Edit: September 17, 2012, 11:49:51 am by EEVblog »
Offline T4P
  • Country: sg
    • T4P
Re: uRuler Gerbers
« Reply #9 on: September 17, 2012, 01:22:39 pm »
Thanks Dave! I'm gonna order a few from seeedstudio
