Author Topic: Cheap source of flexible PCB in china  (Read 2835 times)
Offline ali_asadzadehTopic starter
« on: June 10, 2019, 08:09:50 am »
Hopefully JLCPCB have saved lots of lives! :) I wonder if there is some similar company doing flexible PCB, do we have such a luxury? I have some cool ideas and they are very cost sensitive! do we have some cheap, reliable and online quotation?
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline E.Buer
  • Country: no
Re: Cheap source of flexible PCB in china
« Reply #1 on: June 10, 2019, 09:50:36 am »
PCBway has instant quote on Flex PCBs. Not sure how they compare to JLC pricewise.
Offline fuzzoli
« Reply #2 on: June 10, 2019, 10:02:59 pm »
I have a similar need and found this company:
https://www.goldphoenixpcb.com/fpc-pool.html
I haven't tried them yet, but the concept looks interesting.
Offline KL27x
« Reply #3 on: June 11, 2019, 12:20:17 am »
If you want just 10 boards for prototyping, you might want to check out ITEAD's FPC proto service. You can get 10 small FPC for $100.00.
From a regular manufacturer like Gold Phoenix, for instance, you might have to shell out more than double that to get started. They are gonna charge pretty much the same for 1 board or a whole panel. But you know you can order the production board and it will be exactly the same. And for the higher initial cost, you may be receiving many times as many proto boards. This might be useful if you need more than 10 boards to determine failure rates and manufacturing issues.
If you buy in high enough volume, the price between a vanilla FPC and rigid can be pretty small. FPC is only crazy expensive in small quantities.
Many chinese factories will give anyone quotes. Just take the time to fill out their quote page and upload a gerber. If you're gonna do thru all that trouble, be sure to request quotes for multiple quantities to see what the price:quantity curve looks like. That's what those fields are for. Use them.
BTW, I remember when this was intimidating to me. I talked with some domestic companies. Minimum cost of $1000 for someone to hold your hand through the process. All you really need to know that is different from rigid, as far as buying boards from china, anyway, is a few things. The material is polyimide. It comes in a couple basic thicknesses. 0.1mm or 0.2mm. The soldermask is an additional lamination of polyimide with holes punched in it.  You can add additional laminations/stiffeners or adhesive backings for additional charge. Everything else, you can learn from mistakes cheaper than paying someone with experience.
« Last Edit: June 11, 2019, 12:45:51 am by KL27x »
« Reply #4 on: June 11, 2019, 12:06:28 pm »
Guys thanks for the tips!
