Thanks everyone for the great feedback!
Check your PMs, Pipe2Null. I just sent you a link to overstock from a reputable optical filter manufacturer.
Steve
Awesome, thanks! I'm checking it out.
Is there any reason why your application requires LEDs i.e. having many on/off cycles, free from mercury (by the way low pressure germicidal lamps contain tiny amounts of mercury), no glass to shatter etc.? If not, just use mercury lamps. They're much cheaper and more efficient, than LEDs, given the same power ratings.
My purpose related to UVC is 2 parts:
Part #1) There are a lot of people out there desperately trying to hack together something to sterilize one thing or another. There is a pretty long thread started by a guy who was trying to effectively sterilize the face masks his (medical professional) wife has to re-use. I am not in any way an expert on these things, but I can work to find the right information and post it so those with no other choice but to hack something together might have a reasonable chance at succeeding. I've seen posts where someone says to bake it at 60 degrees C for a while, but I found a study on SARS that required a minimum temperature of 75 degrees, so...
As far as the UVC LED products on Amazon go, I have been told by multiple people that it is not possible to produce a UVC LED light product with a useful LED count that can sell as low as $50 or $100. If those products are scams, not only are desperate people getting cheated out of money, but the sterilization they believe is occurring is NOT, so, if they are indeed scams then the continued sales of those products actually promotes the spread of COVID-19. I kinda think that's a bad thing...
Part #2) I had a crazy idea to use a powerful enough UVC source to sterilize exhaled air in psuedo-real-time from infected people who need to use CPAP/BiPAP/etc for one reason or another. This includes (possibly healthy) people who normally use CPAP on a daily basis but have stopped due to warnings related to COVID-19 being expelled as an aerosol. Theoretically at least, it might be possible to do this with zero filters, which are in short supply globally. I should have a "textbook" on UVGI for surface and air sterilization tomorrow, so that should have most of the important info needed. The problem is availability of UVC sources with minimal lead time, and which ones might be suitable. I freely admit that it is
Bass Ackward to design a "UVC light in a can" aka "bio reactor" based on what UVC source "just happens" to be locally available instead of the other way around. Which brings us back to products currently listed on Amazon. And back to Part #1 since anyone attempting to use UVC for something important has the same problem I'm currently facing.
As for the current thread:
I would appreciate recommendations on a "technical reference/textbook" that contains the right information to measure the output of UVC/radiating sources, preferably one that contains the "cheat sheet" equations to use for typical geometries so you can calculate total output based on point samples taken at specific positions around the UVC source. Hopefully I will not end up needing it, but there is a lead time so I should order it asap. Worst case it will be a welcome addition to my library. Decades ago, I vaguely recall I got a degree in EE, but after many professional years only on the software side of things... Well, saying that I have a lot of relearning and catching up to do is a gross understatement.
