Hi
I'd like to mount a GPS antenna for both gpsdo and as an rtk base station on my roof.
For both applications it should have an open, unobstructed view of the sky. The house has lightning protection fitted and there is a cut down to the roof level antenna mast (for old TV antennas) on the very top, which is already attached to the lightning system. So far so good for the lightning arresting part I guess(?)
However, what kind of protection do I need on the inside? As far as I could gather there should be an earthing point right after entry into the house. Something of that kind:
https://www.amazon.com/Lightning-ARRESTOR-Ham-Base-Antennas/dp/B01LYK5TU5However, I did not really find anything for the frequency range in the ham space nor do the WLAN / amazon type arrestors in the 20-20 bucks range look particularly trustworthy(?)
Also, where the antenna rod goes inside, there isn't really an earthing connection available. Would I just run a 2.5mm2 PE cable from the next outlet / distribution box to the surge protector (about 10m and from there another 15m down to the houses earthing point).
I guess an additional arrestor / overvoltage protection circuit would also be in order since the arrestors I've seen so far in the ham space seem to work with gas discharge tubes and I do not think a gps module likes >50V on it's input
