Hey electroro, if you have followed the data sheet example layout and matching network everything should be ok. The only thing is it seems the your ground plane doesn't connect to the ground pads of the chip antenna. Since you have added "keep out" region where the ground plane cut out should be, it stops the ground plane to properly attach to the GND pads of the antenna.
