Hey guys!
I just bought some thermal epoxy for some testing of Cree LED light bulbs as the dimmers in my house were making them vibrate a lot and I'm also mulling around the idea of building a power supply for myself as well and it occurred to me... I could probably make a pretty nice voltage reference by potting a circuit in this epoxy. One example of a type of circuit I've used in the past involved a LM334 constant-current source IC and a silicon diode for cancelling the temperature coefficient. It didn't work well if you blew on it or something because the two devices were not in thermal contact, but the idea was sound. I figured if I potted it, it would work much much better. Any other suggestions on simple circuits that make good references, especially if thermal contact between components is guaranteed? I kind of want to go somewhat overboard, but also old-school, with my design.
My current BK Precision triple-output supply is nice, but it has some short-comings: I wish it wasn't so heavy. I wish the fan wasn't on 24/7 at full blast. I wish there was one more digit on the current and voltage meters (I'll use 12-bit ADC/DACs). The list goes on.
If you're curious about the light bulbs: The circuit design is legit but it sits in the base almost entirely loose. There's quite a bodge in the design where a fairly large inductor is sitting on the board at an angle because a surface mount diode is mounted below it ... I kind of think that's the main source of noise; however, there are a total of 3 inductors. I drilled a hole in the side and pumped in potting compound and then stuck it in the oven. This didn't work so great as the potting compound seeped out and the film on the glass dome was damaged, but the proof of concept was successful in that the bulb was quieter. Next time I'll probably drill a hole in the glass (carefully!) and just wait for it to cure naturally (... I think it takes like 5 days).
