I wasn't quite sure which category to fit this. It relates to Microcontrollers but relates specifically to the SPI bus and the MCP23S17 chip. It covers issues with the LA probe on my new MSO5000 series scope so does it fall under Test Equipment? It seems that both LA probe and possibly two microcontroller boards have faults, so Dodgy Technology perhaps? In the end I decided it was more generally "Technical Stuff", but too technical to be General discussion and probably not Beginner. However, if its in the wrong place, then by all means, mods, please move to the appropriate category.
In short, I have been having some problems communicating with an MCP23S17 chip via SPI. The story starts over a year ago, I purchased an MCP23S17 and set up a test jig on a breadboard, built a test program, uploaded it to a Mega 2560 and was pleased when all worked as it should. I then added the routines to a particular project. I then started work on the I2C version (MCP23017) and got this working to a point, but it proved unreliable. Eventually, for some reason the MCP23017 gave up. I then reverted to working with the SPI version (MCP23S17) which promptly got fried as well. No magic smoke, no heat. Just stopped working. I don't know why they both got fried, but suspected maybe an overload.
More recently I purchased a new MCP23S17 along with some 270 ohm current limiting resistors to use on the GPIO outputs. So far I have only connected up some LEDs on the PORT A side of the MCP23S17 and the chip was hooked up on the breadboard to a Nano. I loaded up the previously wortking test program but none of the LEDs would light up. (Option 1 should light up Led 8 on GPIO 7, option 2 should light up Leds 2-8, option 0 should turn them all off). I therefore set about investigating this further which became a bit of a saga.
I hooked up the SPI pins to my new MOS5000 oscillscope using an LA probe, the eBay one purchased from the US:
https://www.ebay.co.uk/itm/224648789536This is the first time I have had the occasion to use it since receiving it in January. I then configured the LA, trigger and SPI decoder. The result looked rather weird. The second byte was being broken up into 3 values and the third into two. The CS signal had spikes which coincided with the split point of the values. An analog channel was attached to the CS signal and although there was some noise, it was at no more than 100mV (dupont wires + probe ribbon cable probably contribute) which was well below the threshold of 2.7V so should not have been causing the spikes. CS was moved from pin 10 to pin 8, but with the same result.
The Nano was then swapped out for a spare LG8F328P board which has the same pinout. The spikes on CS were gone, but the numbers were all wrong and the MOSI signal trace looked completely wrong.
A UNO dev board was hooked up instead of the LG8 and the LA waveforms now looked a lot more convincing, but the numbers for the sent bytes were still all wrong.
At this point I should perhaps explain that writing to the MCP23S17 requires a group of 3 bytes - a command byte(read/write), a register byte (port A, port B, or other register to write to), and finally a data byte. During startup, the program sends a total of six write commands which should result in 18 bytes being sent. The output shows only 5 bytes and after the last byte, the pins are left in the wrong state. The byte sequence should be:
0x40, 0x0A, 0x08
0x40, 0x00, 0x01
0x40, 0x0C, 0x01
0x40, 0x01, 0xFF
0x40, 0x0D, 0xFF
0x40, 0x12, 0x80
Instead, the decoder shows random data so for the next step, MISO and MOSI were disconnected from the MCP23S17 chip to eliminate interferance due to a problem with the MCP23S17. The result was unchanged.
The analog probe was now moved from CS to the MOSI channel. The analog pattern did not match the LA trace. Manually comparing the analog trace to the clock did yeild the correct bit values however:
0x40, 0x0A, 0x08
0x40, 0x00, 0x01
So what was the issue with the decoder? Probe wire D1 was disconnected from MOSI and attached to the CLK signal to which D2 was already connected. This should have resulted in the same trace appearing on both channels but the traces were very different. Another unused channel (D4) was connected to the same clock signal for comparison. This resulted in two identical traces on D2 and D4, but a completely different trace on D1. Clearly there is a problem with LA channel D1!
So channel D4 was now connected to MOSI and the decode reconfigured to use that channel instead of D1. Now finally the decoding showed the expected data being sent to the MCP23S17, but unfortunately still no response from the GPIO pins/LEDs.
So there are a number of issues:
a) The Nano clearly has some kind of fault resulting in spikes on the GPIO pins
b) The LG8F328P may also be faulty, but might be worth re-testing now that the problem with channel D1 has been identified.
c) UNO appears to be working OK.
d) channel D1 is not working properly. Is this down to the probe or the MSO5000? How do I test this?
e) MCP23S17 still does not respond to commands. Faulty or fake? Or problem with sketch?
I have attached the sketch (with comments removed) in case anyone spots anything missing or wrong, but this sketch did work before. I should probably point out that A0, A1 and A2 are connected to GND (LOW) so configured for address 0. There is no other SPI device on the bus. Although the Arduino is being configured with an interrupt being attached to pin 2, it is currently disconnected and not being used. INTA on the MCP23S17 is not connected.
I did noit expect to spend so much time on this today, but this is what happened. Obviously, I will need to test all of the LA channels somehow.
Image 1: Nano with spikes on CS
Image 2: LG8F328P with odd MOSI signal
Image 3: UNO with data incorrectly decoded
Image 4: UNO with wrong signal on MOSI (MOSI, CLK and CLK2 all attached to and should be showing clock signal)
Image 5: UNO finally with correct decoding
