Hi electronics enthusiasts!
In my research lab, we are currently investigating the quantum nature of shot noise in photodiodes, and I am designing the transimpedance amplifier circuit needed to be able to measure the small shot noise current produced by a photodiode when a LED is illuminating it. The LED is "mated" to the photodiode with a heat shrink tube in a Chinese finger trap-type contraption. I would like to minimize Johnson-Nyquist noise from the circuit and have the Poissonian noise dominate. It has proven to be rather difficult to get this circuit to work properly on both a breadboard and a protoboard, and therefore I believe I have to spin a proper board for this.
Previous attempts: So far, I have assembled the very same circuit on both a breadboard and on a protoboard, with different results.
Breadboard: The diode's anode is connected to ground and the cathode is connected to the amplifiers inverting input. Furthermore, the amplifier is connected to a single supply with a supply voltage of 5V. The output of the amplifier is fed back through a 1Mohm feedback resistor, and there is no feedback capacitor. The output of the amplifier is also connected to a Keysight frequency counter (DC coupled, 1MOhm input impedance). When light of the same wavelength as the photodiode's central wavelength is incident on the photodiode, the circuit outputs pulses of around 2 volts, and the amount of pulses per unit time is definitely increasing with increased illumination, but nonmonotonically. Obviously, this circuit had all the shortcomings of being assembled on a breadboard together with using ~1 meter long cables with banana plugs from the power supplies, so I am not sure how much noise is coupled to the circuit here.
After measuring the number of pulses per 10ms integration window for 100000 windows, when driving the LED with different currents using a Keithley 2400, I plot the distribution of samples. To this, I fit a Poissonian distribution with the same mean value as the mean value from the recorded data, and I observe that the distribution of the counts do not match. This leads me to think that what I am sampling is, in fact, not the fluctuations in the photocurrent.
What makes me suspicious here is that the pulses are well-formed and "discrete", while I would expect the output voltage to be continuous with a varying amplitude. Many implementations that I have seen use some kind of comparator circuit to digitize the current into pulses. Perhaps the amplifier is oscillating?
Protoboard: Assuming that parasitics are the cause of the pulses I soldered a protoboard with the very same circuit without any success. The circuit instead oscillates at 90 MHz and does not respond to light. I also tried using a L7805CV to supply the amplifier (following the application example in the datasheet), hoping that any noise from the switched benchtop power supplies would be less without success. A naivë thought is that perhaps parasitics in the breadboard actually stabilized the circuit.
Schematic: So, taking what I have figured out from prototyping this circuit, I have drawn up a circuit to be manufactured. Below follow my design choices and my thoughts about the circuit.
Mainly, the circuit is based on the LTC6268 FET-input Op Amp that I already have in my parts drawer. My understanding is that low input bias current amplifiers are good choices for transimpedance amplifiers.
- I have opted to use a gain of 1 MOhm, but as the photodiode datasheet does not specify responsivity, I cannot really estimate what gain is needed. Perhaps this resistor is easily swapped.
- As I don't know whether to run the photodiode in photovoltaic or photoconductive mode, I have added J2 to be able to switch between negative bias and ground.
- The amplifier can run off either a single supply or dual supply, so I have included the jumper J3 to be able to switch between connecting VEE to GND or to VEE_IN.
- The "Power ports"-block denotes placeholders for whatever physical connector/pad I will use for the power supplies.
- Decoupling capacitors are chosen somewhat arbitrarily based on this StackExchange post
- The output is a 50 Ohm SMA, but this can be anything "reasonable" like a scope probe or another IC (DAC)
- The amplifier does not need to supply any significant current, as anything I would connect its output to (DAC/DSO) would be high impedance.
The problem:
The last board I designed (with a great amount of help from the users at EEVBlog!) worked quite well, and the challenge there was high speed and high current capabilities. Here, the challenge is to isolate one noise phenomenon with a very low current, and measure it adequately.
Questions: - Is this a reasonable design to accomplish what I am trying to do?
- I would like to have as high gain as possible to be able to detect the photocurrent, but not too much to have thermal noise in the resistor be the dominant source of noise. Perhaps 1 MOhm is too low gain here?
- It seems like the feedback capacitor is important, but I calculate (using equation 17 here) it to be around 3.5e-14 F, which seems very low
- I am afraid that using jumpers for the bias voltage and for the supply rails is non-ideal and could introduce unwanted noise. Do you believe this could be the case here?
DatasheetsSincerely,
A graduate student who's once again lost in the analog forest
