Hi all,
At the moment I am working in a project making use of a piezoelectric pump. The resonance frequency of the piezo element is about 22 kHz, I have a basic driver to do the job but the resonance frequency changes depending on the load of the pump, the temperature, the air pressure and, obviously, from device to device. The device operates fairly well even though I use a passive circuit driver, which is not hitting the resonance frequency. However the aim is to have the best possible performance and reliability, which might be compromised over time if the device is not used at its resonance frequency.
At the moment I have an alternative active solution using a microcontroller, tracking the maximum current consumption (impedance is the lowest at resonant frequency) and therefore sweeping the frequency continuously to find the sweet spot. I would like to get rid off the microcontroller and use a passive solution to match the right frequency.
Any ideas? In the attachment you can find the recommended driver from the manufacturer of the piezo pump (Murata).
