If it helps, I've got a 300VA toroidal transformer with following specs, you can have for $50 plus postage.
Two independent windings of: 28V (RMS) 5.3A
Primary fuse 3A slowblow
Consider it New Old Stock, was for a project I did long ago, got almost no use.
Comes with the mounting hardware, just need a 7mm bolt/nut to fix it.
