My 2010 Nissan Murano alternator has a bearing going out. While looking for bearing replacements, I came across someone that had removed the rectifier assembly and used an off the shelf 3-phase rectifier to move that portion of the electronics outside of the alternator to mitigate heat damage from the engine. I found that Digikey has a plethora of 3-phase rectifiers that would work for me, including some that have amp ratings far above anything I could ever use in a simple automotive application. The alternator has two sets of 3 phase windings in a wye or star configuration, with each set of windings paralleled at the rectifier. From this, I am confident that I could move the rectifier outside of the alternator with relative ease.
However, I would also like to move the regulator outside the alternator. I've always looked at the regulator as going from the alternator to the engine, but have just learned that it is, in fact, used to regulate the alternator itself so that it doesn't overcharge the battery. Doing some more research, I have come to the understanding that it monitors the output voltage and through PWM, modulates the rotor windings so that at or around 14.4 volts, the effective duty cycle is near or at 0%. This seems easy enough as any simple microcontroller can do both of these things without breaking a sweat. However, those figures represent the upper bound of output voltage and lower bound of PWM duty cycle. In order to do this properly, I would need a voltage at which the PWM duty cycle is near 100%. Also, should the change from 100% to 0% be linear or PID controlled or...? I also read somewhere that the duty cycle transition from fully on to fully off should be more gradual than a square wave to prevent voltage spikes during transition. Would a triangle wave work? Then, I found out about something called load dump. From what I could tell, without a degree in electrical engineering, is that this is basically a flyback diode. I think? The papers I saw, from an older post on these forums, are way over my head. I need this explained in a more simplified manor.
This seems like an easy and fun project, but I have obvious gaps in my knowledge. Can anyone help point me in the right direction?
