For example, folded Ni foil or Ni slip fit tube and spot weld the Ni over a tightly wrapped coil of the Nichrome to the work.
Our fine wire thermocouple welder at work uses a 30,000 uf
Low ESR Electrolytic and a 0.5 to 24 VDC charging supply.
A pulse transformer drives an SCR's gate via a small series resistor. A burst of gate pulses is used to keep the SCR triggered during a weld.
One electrode is usually one side of the work. The other side is some sort of carbon and copper filled sintered block, possibly tungsten that just won't weld under normal energies.
Feed wire to the load is a heavy, very flexible arc welding cable.
We weld a TC alloy very similar to Nichrome
To copper all the time. Not a pretty weld, but tough and conductive. For equal diameter wires, usually a nichrome bead forms around the copper. I know I have a good weld if I
apply a second, smaller pulse, and nothing happens but possibly the leads flopping around with no bang or flash.
If I had to do it all day I'd buy a Sunstone microtig with the retracting electrode and argon gas flood.
There are Sunstone clones on the Bay and Zon, but a true Sunstone has a double pulse. First pulse cleans out any oxide, second pulse is the weld. Self retracting tips work well with fine wire, as stated above, melt the local material just under or beside the fine wire.
Retracting tip clones are Often at few hundred Dollars, vs say 3K for a low end Sunstone. The Sunstone is worth every penny.
https://sunstonewelders.com/products/We have one at work in a sister department. However due to a persistent rumor that argon is optional, and frying the optional resistance welding tweezers with max power on both pulses is fine, I usually have to order handpiece parts before I can use it. The graduate students are in a hurry and they forget that less is often more.
Jewelers use pulsed Nd:Yag lasers for the fine stuff.
Lots of local jewelers have them for repairs. Not that expensive for them, but worth its weight in silver in less then a year of use.
I never do any of these procedures with out at
Least OD4 or OD5 dark eye protection.
Steve
