In my quest to calibrate and test stuff, I find myself needing an AC waveform at various voltages and frequencies.
I have a HP 3325A with the 40V P-P option, but that only gets me so far..
Basically what I am looking for is an amplifier of sorts that will let me hook up my function generator and a high voltage DC PSU or similar (I have a HP beast capable of nearly 500V for example) and invert the DC to a sine wave at high voltage. The higher voltage output the better but 500VAC or so at a couple kilohertz would be fine for most of my stuff.
I can then hook it up to my 34461A Multimeter, set it how I need it then transfer it to the DUT.
It doesn't need to supply much current as it will be used mostly for testing multimeters and the like.
Should I be looking at just a couple transistors and stuff? Or is there an existing circuit I can easily use or adapt?
I'm fine with high voltage as I'm an Electrician across two countries so I know how to handle myself, but I'm sure someone can point straight to a simple(-ish...) way of actually doing this faster than I can figure out google.
