While different aspects of Community Multimeter are discussed on various threads I hope this thread will be a succinct index of information gathered in one place for easy reference.As a starters, here are the relevant HP Journal articles as quoted by alm in
https://www.eevblog.com/forum/index.php?topic=4087.msg54008#msg54008His post encouraged me to start this thread.Full list of the articles from 1949 onwards is available athttp://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/hpjindex.htmlNov-1950, v.2, n.3 -
The 700 Megacycle Voltmeter and Its Applications, by J.R. Petrak
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1950-11.pdfJuly-1951, v.2 n.11 -
Accuracy in -hp- Voltmeters and Oscillators, by R.M. Demere, Brunton Bauer
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1951-07.pdfSept/Oct-1952, v.4 n-1-2 -
Measuring Large Resistances With the -hp- 410 VTVM http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1952-09.pdfJuly-1952, v.3 n.11 -
A Novel Impedance-Measuring System Using Standard -hp- Instruments http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1952-07.pdfMay-1954, v.5 n.9 -
Wider Range and Higher Stability in the new -hp- 4 MC Voltmeter, by John Zevenbergen
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1954-05.pdfDec-1955, v.7 n.4 -
An Enhanced Accuracy High Readability VTVM, by John Zevenbergen
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1955-12.pdfNov-1955, v.7 n.3 -
Step Function Response of Typical Networks http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1955-11.pdfJune-1955, v.6 n.10 -
Some Effects of Waveform on VTVM Readings (Conclusion), by B.M. Oliver
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1955-06.pdfMay-1955, v.6 n.9 -
Some Effects of Waveform on VTVM Readings (II), by B.M. Oliver
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1955-05.pdfApril-1955, v.6 n.8 -
Some Effects of Waveform on VTVM Readings (I), by B.M. Oliver
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1955-04.pdfJuly/August-1959, v.10 n.11-12 -
A Precision DC Vacuum-Tube Voltmeter with Extended Sensitivity and High Stability, by Donald Norgaard
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1959-07.pdfJan-1959, v.10 n.5 -
A New Digital DC Voltmeter with Automatic Range and Polarity Selection, by Theodore C. Anderson, Noel M. Pace
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1959-01.pdfSept-1960, v.12 n.1 -
A New RF Millivoltmeter for Convenient Measurements to 1 Kmc, by Theodore C. Anderson
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1960-09.pdfJuly/August-1960, v.11 n.11-12 -
A New Clip-on Oscilloscope/Voltmeter Probe for 25 - 20 MC Current Measurements, by Charles O. Forge -
The Value of AC Current Measurements, pg 5
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1960-07.pdfMarch-1961, v.12 n.7 -
Increasing Accuracy in -hp- Meters Through Servo Calibrating Methods, by Bernard M. Oliver
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1961-03.pdfFeb-1962, v.13 n.6 -
A New Digital Voltmeter Having High Rejection of Hum and Noise, by R.A. Andersen
http://www.hpl.hp.com/hpjournal/pdfs/IssuePDFs/1962-02.pdf...... TO BE CONTINUED.......
