Author Topic: Components clearance in Altium  (Read 137 times)
Offline Nikos A.
  • Country: cy
« on: June 18, 2021, 09:01:40 pm »
Hi everyone,
I am facing an issue that I cannot workaround. I have set 0.254mm clearance for all components as you can see from the screenshot below and I use the Moving [Push: avoid] option while placing the components. For some components the clearance differs from what I have set in design rules. For example, I can place R22 0.254mm close to another component BUT if I rotate R22 then the minimum distance I can place it close to that component is around 3.3mm. I can place it closer only if I use Moving [Push: Ignore] option.
What is the problem behind this issue? This could be related to the footprint, or is there any design rule I have to check, or maybe this is somehow related with system preferences? This issue also applies for some other components. I also attach the 3D view in case that it is helpful
Here I have rotated R22 and as you can see I cannot place it closer than 3.3mm
