Author Topic: Components you wish existed.  (Read 44675 times)
Online Circlotron
Re: Components you wish existed.
« Reply #50 on: May 11, 2017, 11:43:43 pm »
Be careful what you wish for!
Fifteen years ago I was for quite a while involved in the design of lossless passive resonant snubbers for PFC boost converters. When the mosfet turns on you have reverse recovery current in the main diode so you put a small inductor in series with this diode to taper off the main current then ramp up the reverse current to suck out the stored charges in the diode pn junction in a controlled way. Then you have to capture the energy in this snubbing inductor and using diodes and caps return it to the main output. Great fun and it looks like art and ran like clockwork when it is all done. Back then we wished for perfect diodes to simplify life a bit, and then Lo and behold, along came high voltage silicon carbide Schottky diodes! They worked so much better and simplified the circuit greatly. The unexpected downside though was that there was almost no satisfaction in getting this much simplified circuit up and going. Sure it worked better and from a commercial point of view it was a success, but when you make stuff at home a lot of it is for the ahhhh factor. This new circuit had none of that.
« Last Edit: May 12, 2017, 12:44:22 am by Circlotron »
Offline nuno
  • Country: pt
« Reply #51 on: May 11, 2017, 11:46:23 pm »
Maybe merge both topics?
https://www.eevblog.com/forum/chat/components-you-wish-existed/
3 years later looks like Mike's still craving for a 74HC138 or HC595 with 1A P-channel source drivers on the output :)
« Last Edit: May 11, 2017, 11:50:52 pm by nuno »
Online mariush
« Reply #52 on: May 12, 2017, 12:02:35 am »
I'd like to see more switching regulators available with built in inductors and diodes and ceramic capacitors.. in DIP or soic or something like that. Basically just add input and output capacitors and you're done.  Linear has a bunch of them but they're mostly BGA or similar packages and cost a lot (15$+). Don't see why it would be so hard to make cheap ones with just vin , vout and maybe adjusting output voltage using a resistor.
Do you know about these?
https://www.altera.com/products/power/devices.html#powersoc-converters
Interesting, wasn't aware of those. Still, the first one I checked is again, expensive.. 11$ for EN2340QI : https://www.digikey.com/product-detail/en/altera/EN2340QI/544-2845-2-ND/4430952
Here's what I was looking for at while ago, the basic scenario ..  make a fan controller that can accept 2 pin to 4 pin fans ... detect if fan is plugged in by rpm sensor or by measuring current pulled by fan when it starts,  if there's 4 pin fan detected, use pwm to adjust speed otherwise control fan by adjusting the voltage from the dc-dc converter (could use pwm on the actual power sent to the fan but that could mess up the rpm wire) .
So basically the ideal dc-dc converter for this would be 14v max input, 5v to 12v output, at least 0.5A but capable of 1A or a bit more for a second or so while the fan starts up , protection against short circuit (if dumb user blocks fan with fingers or something else happens that would short the output.. at least for a few seconds until the microcontroller or some circuit reacts and turns off the converter with its enable pin). Would be nice to have more than 0.5A but wouldn't be required.
Even better if such a dc-dc converter could be configured through i2c or spi to simply set the output voltage.
All those Altera seem to be either 6v in , less voltage out , or 14 v in , max 5v out .. wouldn't work for this scenario.
Microchip has some fan controller ICs that can control multiple fans but they seem to work mostly with 4 wire fans , not with plain 2wire or 3 wire fans. They're nice ICs controllable through i2c but not perfect.
Offline DBecker
« Reply #53 on: May 12, 2017, 12:04:52 am »
I would like a 'perfect' active-synchronous bridge rectifier.  Like four IR11672, but without the external components, in a standard bridge rectifier footprint.
And a similar part for low voltage, perhaps integrated with a switching buck/boost regulator.  That would allow using any power brick up to 24VAC with small gadgets.
A symmetric VIPER chip, that takes 120+120VAC referenced to neutral/ground and draws equally from each leg.  It probably needs a  ground continuity test feature and a fault LED output.  This should be able to safely power the control circuitry of 240VAC appliances that have grounded control panels, without using X or Y capacitors.
Offline Neomys Sapiens
« Reply #54 on: May 12, 2017, 12:38:43 am »
And also, a little thing that transports heat ELSEWHERE by quantum linkage. Sort of an infinity heatpipe.
Offline karoru
« Reply #55 on: May 12, 2017, 12:47:33 am »
I'd like to get modern equivalent of XR2206. Many hobbyists want to build their own function gen and they end up buying NOS XR2206 for price comparable to serious FPGA, because that "add few switches, passives and buffer" construction is so tempting.
Online Circlotron
« Reply #56 on: May 12, 2017, 12:52:27 am »
I would use one of those to build an air conditioner with one end in a hot climate and the other in a cold climate. Users at both ends get the benefit. The ultimate win/win machine.
Online Circlotron
« Reply #57 on: May 12, 2017, 01:02:50 am »
An ultraviolet LED that was the right wavelength to erase EPROMs.
Offline BrianHG
« Reply #58 on: May 12, 2017, 02:29:39 am »
A xenon strobe light with a few flashes does it in around 5 secs.  A really bright UV Led will still take a good 5-10 min.
__________
BrianHG.
Offline BrianHG
« Reply #59 on: May 12, 2017, 02:35:46 am »
A solar cell which converts all of the visible light spectrum + near IR, to electricity with over 75% efficiency, cheap and large and high voltage in a single cell.
__________
BrianHG.
Offline Conrad Hoffman
    • The Messy Basement
« Reply #60 on: May 12, 2017, 03:37:04 am »
The available 2206 parts I've tried are not the same as the original 2206. They only meet spec, sweep in particular, over a narrow voltage range. IMO, the only good solution for function generators today is discrete, like the circuits used in various Waveteks, or DDS chips.
Offline blueskull
  • Country: cn
  • BA7LKP
« Reply #61 on: May 12, 2017, 04:00:50 am »
Check out AMIS C5N process, you may be able to get MPW runs for this process at very low price.
If you can find a market for this and can sell as few as 10k chips.
It supports HV devices (with high side N FET possibility, not triple well, but nested drain) and it supports SCMOS rules (so you can use free EDA tools such as ElectricVLSI).
If you are a student you can try to contact MOSIS for a FREE MPW run on your design.
Offline radar_macgyver
« Reply #62 on: May 12, 2017, 04:31:26 am »
Something like a 74HC138 or HC595 with P-channel MOSFET outputs that can source a couple of amps.
It is over 1A technically, so would the NXP MC33879A count? Otherwise, the ST L9848 can handle 0.8A. Others can be found under "PMIC - Power Distribution Switches, Load Drivers" at Digi-key.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #63 on: May 12, 2017, 04:32:26 am »
VCCap = voltage controlled capacitance
VCInd = voltage controlled inductance
VCRes = voltage controlled resistance
analog version, not some stair stepped digital trick. various size smd, TH, various C and L range, various power rating. i know there is digital VCRes or somesort of control, but i'm not aware of VCCap and VCInd even in digital trick.
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
Offline james_s
« Reply #64 on: May 12, 2017, 04:39:59 am »
I suppose a saturable reactor could be considered a voltage (or current) controlled inductor.
Offline jonovid
    • JONOVID
« Reply #65 on: May 12, 2017, 04:44:18 am »
artificial silent running muscle for robots. no more mechanical linear actuators,  the use or invention of a type of dynamic filaments producing contraction by say electrical currents, not by buzzing mechanical drives.
Hobbyist with a basic knowledge of electronics
Offline BrianHG
« Reply #66 on: May 12, 2017, 04:55:22 am »
This exists, it's called a tuning diode.
Also known as varactor diodes.
Also, higher voltage zener diodes also can be used as tuning diodes.
« Last Edit: May 12, 2017, 04:59:08 am by BrianHG »
__________
BrianHG.
The following users thanked this post: Mechatrommer
Offline sleemanj
  • Professional tightwad.
« Reply #67 on: May 12, 2017, 05:43:38 am »
A true ideal diode, two pin, some sensible SMD diode-sized package, drop it in, job done.
Logic level mosfet without body diode.
Offline Roeland_R
« Reply #68 on: May 12, 2017, 05:58:51 am »
Fluxcapacitor
But where are you gonna get the 1.21 gigawatts of electricity?!
From a Duracell ofcourse.
Offline TJ232
  • www.esp8266-projects.com
    • ESP8266 Projects
« Reply #69 on: May 12, 2017, 06:11:48 am »
CR2030 or 2025, for standard housing applications, half a gig lasting for at least 10 years (leakage current, you know...) might be enough for me.
Offline jbb
« Reply #70 on: May 12, 2017, 06:18:11 am »
FPGA co-packaged with large DRAM.
(This won't happen because FPGA customers demand long term (>10yr) availability os the same part and DRAM chip manufacturers only offer a given die for a few (maybe 5) years.)
Offline blueskull
  • Country: cn
  • BA7LKP
« Reply #71 on: May 12, 2017, 06:23:53 am »
Maybe, but if FPGA is copackaged or even co-died with a CPU, then the lifecycle requirement is much shorter.
We are all expecting Intel's next Xeon FPGA.
Offline AndyC_772
« Reply #72 on: May 12, 2017, 06:28:42 am »
Most of the range is designed to do 5V in, low voltage out, which is absolutely ideal if you're designing a logic board with lots of devices all requiring different supplies. These parts are my go-to solution to power microcontrollers, FPGAs, DRAM, and any other kind of logic device requiring a low voltage supply. They're compact, efficient, and have that superb, intangible "just work" quality.
For example: EP5357HUI will do 5V in, 3.3V @ 600mA out for $2 in 100+ quantity, and it's just 2.5 x 2.25mm. Amazing.
Online Circlotron
« Reply #73 on: May 12, 2017, 07:18:24 am »
Decent capacity 5 volt parallel flash memory.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #74 on: May 12, 2017, 07:38:07 am »
Actually, if you only need to hold that wattage for a second, then it's not that bad.  If you need to dish out that total power in one second, then you got some real problems.
That's 336 kWh of energy
