Author Topic: Components you wish existed.  (Read 44623 times)
Online richard.cs
  • Electronics engineer from Southampton, UK.
    • Random stuff I've built (mostly non-electronic and fairly dated).
Re: Components you wish existed.
« Reply #75 on: May 12, 2017, 08:13:16 am »
That's 336 kWh of energy
About the energy in a large sack (about 40 kg) of coal.
Even in 1955 a couple of GW peak power could have been achieved by driving into HV electricity distribution cables.
Offline Kjelt
« Reply #76 on: May 12, 2017, 08:43:20 am »
It would have made the BTF movie quite boring if they just had to plug it in.
Offline Sredni
  • Country: aq
« Reply #77 on: May 12, 2017, 08:50:47 am »
Untanglable cables.
Also, the word "untanglable".
Offline Codebird
« Reply #78 on: May 12, 2017, 09:15:35 am »
The Space-Folding antenna: DC-to-daylight bandwidth and 100% efficiency in a handy 5cm package. No more wires longer than your garden to work the HF bands.
Offline timb
    • timb.us
« Reply #79 on: May 12, 2017, 01:50:08 pm »
artificial silent running muscle for robots. no more mechanical linear actuators,  the use or invention of a type of dynamic filaments producing contraction by say electrical currents, not by buzzing mechanical drives.
It exists! Check out Muscle Wire (aka Nitinol). It's a shape memory alloy made from nickel/titanium. Passing current through it generates heat, causing it to contract.
It's been commercially available for at least 20 years.
« Last Edit: May 12, 2017, 01:51:54 pm by timb »
Online ChristofferB
  • Chemistry phd student!
    • My channel:
« Reply #80 on: May 12, 2017, 01:52:32 pm »
Fluxcapacitor
But where are you gonna get the 1.21 gigawatts of electricity?!
Actually, if you only need to hold that wattage for a second, then it's not that bad.  If you need to dish out that total power in one second, then you got some real problems.
Unfortunately they sort of glossed over those details in the movie.
One thing I've always wanted to know is how did he fit a nuclear power plant into a car? It would have been more believable if the flux capacitor was based on nuclear fission directly rather than electricity.
And IF you had a conventional nuclear power plant in a car, it'd be a minor (in comparison) conversion having the car itself run off of it too.
-A passive directional coupler that works ideally from DC(almost) to 10+GHz would be neat!
--Christoffer
Check out my scientific instruments diy (GC, HPLC, NMR, etc):
Channel: https://www.youtube.com/channel/UCZ8l6SdZuRuoSdze1dIpzAQ
Offline dimkasta
  • Country: gr
« Reply #81 on: May 12, 2017, 02:08:16 pm »
High gain, ultra low noise, low capacitance, truly complementary and matched Jfets
And the same thing on power jfets
Offline w2aew
    • My YouTube Channel
« Reply #82 on: May 12, 2017, 02:26:09 pm »
VCCap = voltage controlled capacitance
VCInd = voltage controlled inductance
VCRes = voltage controlled resistance
analog version, not some stair stepped digital trick. various size smd, TH, various C and L range, various power rating. i know there is digital VCRes or somesort of control, but i'm not aware of VCCap and VCInd even in digital trick.
There are voltage controlled capacitors (for small capacitance values), it is called a varactor diode, or varicap diode.
Also, a MOSFET can be used as a voltage controlled resistor it its linear region.
For AC/RF applications, a PIN diode is a voltage controlled resistor.
FAE for Tektronix
The following users thanked this post: Mechatrommer
Offline DJohn
« Reply #83 on: May 12, 2017, 03:47:17 pm »
FPGA co-packaged with large DRAM.
Xilinx XCVU37P.  FPGA with 8GB of DRAM sitting on top.
The following users thanked this post: jbb
Offline babysitter
  • pushing silicon at work
« Reply #84 on: May 12, 2017, 03:49:38 pm »
Use a core with two wire loops, use the one for your application, apply A DC voltage to the second. when you get close to saturation... tadaaaa!
(Once had >Rohde & Schwarz SWOB II that uses this to tune some oscillators that way.)
I'm not a feature, I'm a bug! ARC DG3HDA
The following users thanked this post: ali_asadzadeh, BrianHG
Offline IanJ
  • Country: scotland
  • Pro EE guy many years ago, now a hobby/home biz.
    • IanJohnston.com
« Reply #85 on: May 12, 2017, 03:49:43 pm »
zero ppm/degC resistors of all sizes and cheap.
I'll get ma coat......
Ian.
Ian Johnston
www.ianjohnston.com
Manufacturer of the PDVS2 & PDVS2mini
Offline JanJansen
« Reply #86 on: May 12, 2017, 04:10:49 pm »
3.) linear thermistors
Tempco resistors ?, i need those also.
They do exist, only not for sale anymore.
aliexpress parachute
Offline KL27x
« Reply #87 on: May 12, 2017, 10:15:42 pm »
8-bit Optocoupler Isolator in DIP package.
There is a reason this doesn't exist. If you stack 8 single DIP optocouplers side by side, they fit the same footprint and have the same pinout. And per cost of the devices, it will be cheaper and have greater flexibility.
If you want to save money on board and assembly cost, and you are using DIP, you are doing it wrong. I wonder what you are prototyping that this package will save you considerable time and effort. :)
« Last Edit: May 12, 2017, 10:18:26 pm by KL27x »
« Reply #88 on: May 13, 2017, 05:39:11 pm »
Vacuum thermistors for oscillator stabilization. They used to exist and weren't too expensive, but now unobtainium. Last I saw were the Bowthorpe or NTC RA series. Lots of data sheets out there, but nobody seems to have actual parts.
About the only replacement I can suggest is to get a small grain of wheat lamp, 28VDC rating, and use that. Tungsten filament, vacuum sealed, and does work well when run at under 3V on the filament, with a good control range and only minor room temperature dependence. You will have to drive with a higher current than the RA53 ( I do actually have some in a pack here, but the lamp was easier) but not that much more.
Like this one
http://za.rs-online.com/web/p/filament-indicator-lamps/6559479/
« Last Edit: May 13, 2017, 05:45:11 pm by SeanB »
Offline carljrb
« Reply #89 on: May 13, 2017, 08:29:28 pm »
It just feels wrong, somehow, to use a microcontroller for something so trivial.
To some extent it does but sometimes it's the least bad solution.
Sure, you can make something out of a bunch of circuits (large and expensive, not flexible), or use something like a LTC6992 indeed, but it's an expensive part and that might still require a bunch of circuitry to make it work as you'd wish. I just made something like this out of a PIC10F320 because it was simpler, more flexible and cheaper overall.
It's a a simple fan controller, with a MCP9701 temp sensor (analog), and a cheap but good enough logic level N-Ch MOSFET driving the fan in PWM (no feedback). This way I can change the temperature at which the fan starts, which PWM % the fan starts at, and what the curve will be like overall. Setting those things in hardware would have sucked in many ways. Here the code is easily tweakable, and the total BOM including the PCB is under $2.
The main downside is that the PicKit ICSP header is kinda big for the board. The temp sensor, MCU, LDO and MOSFET are all SOT-23 so it's quite a small board.
Offline jbb
« Reply #90 on: May 13, 2017, 09:56:42 pm »
We are all expecting Intel's next Xeon FPGA.
Oh yes, yes we are.
It's gonna be fun watching the high level language guys run smack into the realities of FPGA work  >:D.  Even the best high level 'software' code to Hardware Descriptor Language (HDL) generators won't deliver good results unless you understand the reality of how an FPGA works.  This might cause opportunities for embedded / HDL people to change roles a bit if they want to.
Offline theatrus
« Reply #91 on: May 13, 2017, 10:14:26 pm »
Look into the TagConnect if you want something much smaller without resorting to custom pinprobes.
Software by day, hardware by night; blueAcro.com
Online retrolefty
« Reply #92 on: May 13, 2017, 10:19:59 pm »
 Actually around 40 years ago I first ran across Foxboro chart recorders that used Nitinol wire 'motors' to drive the plotting pin across a rotating paper strip. Very linear, medium speed, but somewhat current heavy and Nitinol was somewhat pricey in those days. Cool stuff, there are sources for hobbyist and can be pretty cool in some unique applications.
Offline BrianHG
« Reply #93 on: May 13, 2017, 10:23:56 pm »
Lithium Oxygen battery packs.
Well, if I wait long enough, they should be with us in around 15 years.  The bigger question is how affordable will they be?
__________
BrianHG.
Offline cdev
« Reply #94 on: May 13, 2017, 10:42:14 pm »
Most of us already have such an ability, and don't realize it. Its in the earth. You just need a heat exchanger that can properly utilize it. A typical system uses buried pipes. Depending on what the average temperature of the earth there is you can potentially save substantial amounts of energy this way.
Most people have had the experience of being in a cave. Even in areas where outside its a boiling desert, or frigid weather, the temperature in caves underground stays relatively stable year round. You might need a little bit of boosting to get it to 72 in the winter and it might be difficult to achieve really low temps in summer, but "geothermal" as its called really is a huge potential money saver. The biggest one time cost is getting your heat exchanger deep enough, usually they will use buried pipes in a deep trench going back and forth.
Quote from: Circlotron on 2017-05-11, 18:52:27>Quote from: Neomys Sapiens on 2017-05-11, 18:38:43
And also, a little thing that transports heat ELSEWHERE by quantum linkage. Sort of an infinity heatpipe.
I would use one of those to build an air conditioner with one end in a hot climate and the other in a cold climate. Users at both ends get the benefit. The ultimate win/win machine.
Online blueskull
  • Country: cn
  • BA7LKP
« Reply #95 on: May 14, 2017, 12:12:42 am »
That's why Altera and Intel have spent so many years on OpenCL, and Intel knows exactly how to do OpenCL correctly.
Intel had a failed attempt on creating x86+FPGA SoC, and the failed product is Atom E6x5C.
It is basically an Arria 2 copackaged with an Atom E6x0, connected through PCIe.
At that point, Altera hadn't touched OpenCL yet, so as you can expect, software engineers didn't really know what to do with the extra Altera silicon.
I guess Intel has learned enough from its failed attempt, and by acquiring Altera, they should have even more understanding on FPGA SoC design and OpenCL implementation.
Offline westfw
« Reply #96 on: May 14, 2017, 05:31:36 am »
Switching regulator with built-in inductors:  TI "nanomodules": http://www.ti.com/product/lmz20502 and similar.
They're supposed to be reasonable cheap "in quantity."   They're about $5 in small quantities.  Various other vendors have similar modules.  Murata, Torex, Recom...  https://www.digikey.com/products/en/power-supplies-board-mount/dc-dc-converters/922?k=&pkeyword=&pv1525=94&FV=15c0002%2C9540008%2Cffe0039a&mnonly=0&newproducts=0&ColumnSort=0&page=1&quantity=11&ptm=0&fid=0&pageSize=25
Offline westfw
« Reply #97 on: May 14, 2017, 05:35:19 am »
I'd like a micrcontroller "pin amplifier."  Something that would push/pull 5V@200mA or so from a wimpy 3.3V ARM chip, AND sense/handle input as well.  They make auto-sensing bi-directional level translators, and they make H-bridge drives/chips; I want their functionalities combined.
Offline GeorgeOfTheJungle
  • Country: tr
« Reply #98 on: May 19, 2017, 02:43:59 pm »
Magic smoke refills !!!
Offline BrianHG
« Reply #99 on: May 19, 2017, 03:32:23 pm »
Affordable 1KW, dentin free, noise free, 3 phase permanent magnet generator with over 90% efficiency right from 15 rmp through 150 rpm, at all voltage and current loads, with over 98% efficient ideal diode bridge rectifier.  (Looks like I gonna hire/contract a specialist engineer to work on this one...)
Wind turbine, I assume?
Exercise bike...
Though, over 1kw is intermittent.  Top riders can sustain an average of 700 watts at the pedals for an hour under occasional peak performance conditions.  I don't want gearing and, IE crank shaft right on the motor, but I also need to simulate the effect of a flywheel for the lower RPM and the sharp transition multi-ton torque point generated when a rider shifts his weight on each peddle when sprinting.  I might be stuck with a chain & gear up to a pancake generator to increase RMP & have a bit of mechanical flywheel effect to aid the software loading, but, I'll loose power efficiency when sending the surplus generated back to the grid and increase weight and frame/chassis complexity.
« Last Edit: May 19, 2017, 03:37:17 pm by BrianHG »
__________
BrianHG.
