Author Topic: Computer controlled power supply  (Read 11540 times)
Offline House91320Topic starter
« on: May 25, 2011, 11:08:10 pm »
 My friend and I are building a computer variable power supply and were wandering if there is a way to input 0-5 and out put 0-30.
Offline scrat
Re: Computer controlled power supply
« Reply #1 on: May 26, 2011, 12:49:01 am »
Can you be a little more clear?
If you mean input voltage < output voltage, there are switching topologies making it possible (under certain limits, of course).
One machine can do the work of fifty ordinary men. No machine can do the work of one extraordinary man. - Elbert Hubbard
Offline stl
  • Country: pt
« Reply #2 on: May 26, 2011, 12:50:09 am »
You're making a variable power supply from an ATX power supply? How much current will you need?
You can see here how you can do it:
http://www.wikihow.com/Build-Your-Own-Variable-Bench-Power-Supply-Using-an-ATX-Power-Supply
It's fairly easy to make one variable between 1.3~22V, but up to 30V it's more tricky, I've done one recently that I can adjust between 1.33-33V but didn't tested properly yet with a "heavy" load.
You will read some opinions advising you not to do it and just buy a proper bench power supply, witch I also recommend, but if the cost is a issue there are other solutions. It all depends of what you need it for, how much current you will you need. Using a computer power supply may not be the best solution for you...
« Reply #3 on: May 26, 2011, 02:51:11 am »
I should have specified my friend and i would like to make it a liner supply. the control of the supply has to be 5 volts not the vi.
Offline Bored@Work
« Reply #4 on: May 26, 2011, 05:47:54 am »
Let me ask if you are clear on the concept that you can't make 30 V out of 0V? You are aware of the concept that you need to put more power in than you will get out? A 5V 100mA source will not give you more then 17mA at 30 V, in practice you'll be lucky if you get more than 10mA.
As for the rest, yes, there are SMPS topologies where the input voltage can be within the range of the output voltage. E.g. SEPIC, the similar Zeta converter, Cuk converter, or buck-boost.
An SMPS with variable output is tricky, regulating it continuously down to 0V is even more tricky. Using a SMPS as a tracking pre-regulator to a linear regulator, might be an option. The linear regulator then still needs to be specially designed to regulate down to 0 V.
Offline Balaur
« Reply #5 on: May 26, 2011, 06:41:30 am »
I think he's asking for a way to control the output of the supply using a computer.
The second question consists in: "it is possible to control the output voltage with an 0-5V input voltage?"
Yes, there are variable power supplies with a remote control capability. Example: http://dangerousprototypes.com/docs/Leon:_Computer_controlled_power/current_supply,_multimeter
A simpler implementation is to try a wide output voltage regulator that requires a resistor to set the output voltage. Then, use a digital potentiometer instead of the resistor to vary the voltage.
Example: http://www.maxim-ic.com/app-notes/index.mvp/id/183
Offline RayJones
    • Personal Website
« Reply #6 on: May 26, 2011, 08:19:32 am »
OP, yes you can.
I presume 0V in = 0V out, 5V in = 30V out.
You need to use your PC supplied voltage as a reference in the feedback loop via a comparator. ie control the feedback loop.
To get the desired range, you'd need to attenuated the actual output voltage in a 6:1 ratio (eg simple resistor divider) to compare against the PC's value.
The error from your comparator can then be used to adjust the output volts accordingly.
« Reply #7 on: May 26, 2011, 05:40:06 pm »
i think there is a mis under standing the regulator vin is 30 an the desired v out is 0-30 what i am trying to figure out is how to control the regulator with a 0-5 analog voltage.
Offline firewalker
  • Country: gr
« Reply #8 on: May 26, 2011, 07:38:10 pm »
You will need something like the following circuit.
Alexander.
« Last Edit: May 26, 2011, 08:13:41 pm by firewalker »
« Reply #9 on: May 26, 2011, 09:00:19 pm »
thats perfect thank you
« Reply #10 on: May 26, 2011, 09:39:34 pm »
Also little of topic but where is a good place to get a high power transformer.
Offline RayJones
    • Personal Website
« Reply #11 on: May 26, 2011, 09:42:13 pm »
That's too hard - we don't know where you live  :D
Offline stl
  • Country: pt
« Reply #12 on: May 26, 2011, 11:24:10 pm »
How have you manage to control the variation between 0 and 5V using the computer?
Offline sacherjj
« Reply #13 on: May 27, 2011, 03:54:17 am »
PWM with low pass filter?
