It's called a high side gate driver, and yes, they are plentiful.
If you need DC operation, find one with an integrated charge pump, or create an additional supply to deliver (+Vcc) + 10V or so.
If all you need is the switch, consider using a purpose-made load switch IC, which includes the driver logic, supply, power transistor, and all the protection you might desire (voltage, current and temperature). Also check under "hot-swap controller", those have similar functionality while supporting an external transistor (that can be much bigger).
