If by redundancy you mean combining multiple different, iffy input power sources (think about power harvesting, for example) to make one more reliable output, it could theoretically make sense. (Although I would just diode-or the inputs together, then use one regulator.)
If by redundancy you mean protecting against regulator failures, it won't work that way. The regulators do not just fail for no reason. They only fail if there is a catastrophic design failure somewhere, in which case it's very likely all three will fail in no time.
OTOH, if you really need super high reliability (think about life support systems), it's going to be much more difficult than just simply paralleling some regulators.
