Author Topic: Slope detection circuit or Edge detection circuit proposal  (Read 844 times)
Offline zero0dTopic starter
  • Country: hr
« on: March 15, 2022, 02:33:34 pm »
Hi All,
i need some help to put me in to right detection and to choose the right circuit for slope or rising edge detection circuit using OPAMP or Comparator or something else :)
Here is my block diagram in attachment:
1) i have a hall current sensor eg from Infineon PN: TLI4971-A025T5-E0001.
I'm applying current pulses to the hall sensor:
-> The current can be from 100mA to 10A ( the hall sensor will produce voltage with 1us delay at the output from 0V to 5V depending on the current)
-> The current pulses can have ton_min= 10us , ton_typ = 100us, and a typical frequency of 100Hz to 1kHz
2) on the other hand i have a mcu of FPGA digital input, when goes from low to high ( means current is pressent), when goes from high to low ( current not present, but this transition is not critical)
Primarily i want to detect the current is present.
3) So I'm looking for a circuit that can detect the rising slope and give a high(3.3V or 5V) to the MCU for the given range of currents (100mA to 10A)
I was thing about a non-inverting differentiator or a input AC coupled non inverting OPAMP with high gain and high speed GBW, but i can't find much data on those approaches.
Thank you and Br.
Offline Terry Bites
Re: Slope detection circuit or Edge detection circuit proposal
« Reply #1 on: March 15, 2022, 03:17:35 pm »
Something like this? Adjust R2 for threshold.
  • Country: hr
« Reply #2 on: March 16, 2022, 07:10:54 am »
Hi Terry,
i tried the simulation in TINA-TI, but i didn't get a behavior that i want. (Attached, need to run Analysis Transient)
One thing i noticed in your picture is that you didn't use square signal on the input, why? the signal from Hall sensor is square ( in my sim i used 480mV amplitude that represents 10A current)
  • Country: hr
« Reply #3 on: March 16, 2022, 07:17:48 am »
Ok, i now got it to work , need to change the threshold very  low :D -> I set the R1( your R2) to 1k.
Also i have to check if it will work with 5mV input.
It now works, but it is inverted.
