Author Topic: Current sensing noise consideration in FoC capable BLDC Motor driver  (Read 1022 times)
Offline satyamfifaTopic starter
Hey Guys,
I am designing a 48V, 30A continuous current FoC capable BLDC motor driver. I want to do in-line current and voltage sensing in all three phases plus total current sensing. For this I was to use shunt resistor about 0.001 \$\Omega\$ each connected to INA240 current sense amplifier which is connected ADS7947 (12 bits 2MSPS) ADCs which has SPI interface, each ADC has two channels therefore I am thinking of using one channel for measuring phase current and other for phase voltage. I am thinking of placing one shunt resistor, amplifier and ADC close together for each phase.
However, the thing I am really considering now is the impact noise generated by MOSFETs switching high current on current sensing circuit and how can it be minimized. I am considering using separate ground planes for the sensing circuit, I have been doing quite some research on separating ground planes and I have heard argument both for and against doing so, and because I am measuring frequencies below 20 kHz, I am thinking this could be good idea. I understand that ADCs and Amplifiers referencing should be tightly coupled together since any noise / offset with affects them both will be cancelled out.
Another design decision that I am not really sure about is weather to power the analog circuit from 3.3V directly from the logic board, to power it with 5V requiring me to add a LDO which is sourced from 48 V input.
Finally, I am also concerned about the signal integrity of the SPI signals if the ADCs are placed close to amplifiers which mean they might be placed further away from the logic board. I assume that SPI clock frequency will be a typical of 34 MHz.
I think the right component placement will be key to achieving the most optimal design. I would really appreciate any suggestions, tips, possible solutions, considerations etc.
Kind Regards,
Sparsh
« Last Edit: November 16, 2021, 10:09:47 pm by satyamfifa »
Offline Benta
Re: Current sensing noise consideration in FoC capapble BLDC Motor driver
« Reply #1 on: November 16, 2021, 09:52:53 pm »
The most ambitious and problematic point in your post is using 1 m\$\Omega\$ resistors for current sensing.
Offline jonathan_nadar
  • Country: in
Re: Current sensing noise consideration in FoC capable BLDC Motor driver
« Reply #2 on: November 17, 2021, 03:53:54 am »
You can refer to this document from TI.
The following users thanked this post: satyamfifa
