Hurray !!!! Success !!! Previous dump was corrupted by the Hex viewer. Attached is the correct one in.txt format. I managed to find 4 codes that all work. Marked them aa, bb, cc, dd (small caps) in the file. This is the only modification I did to protect my real codes. The real codes were at those locations. I know that aa is the Master Code and dd is the Installer code. Not sure what codes bb and cc are but I don't care at this point. The location of the codes is certainly different than the ones mentioned in other postings online. As I said my system is an older version of Concord circa year 2003. Hope this will help other users.
