After a long period, I'm close to finishing an air brush compressor. It was originally a retail oiless compressor, but for my use indoors it was just to loud in operation. I replaced the new oiless compressor with two refrigeration compressors, single phase. Along the way I've had a few problems, from adding wheels to the base and it toppling over destroying both relay control boxes. So had to rework an alternative wiring input solution, the unit uses a pressure switch with a high current SPDT relay to control the compressors and solanoid unloader valve. Its all working fine, but where I've used clear braided air line for the output air, I've noticed condensation in these discharge airlines. I was wondering if any of this condensation is likely to find its way back into the compressors ? The compressors are well lubed up with 300ml of compressor oil in each unit. The discharge tubes air descending in there angle as they leave the output port on each compressor. So unlikely to find condensation climbing back up these air lines. But it still remains a wet environment inside these discharge airlines. I'm thinking as the compressor inside has oil around it, it should be fine. But the site of water droplets in the discharge lines doesn't make me feel confident about it. I know all compressors accumulate water in there function, and ends up in the air receiver, and then drained off periodically. So my question is should I need to alter something from the discharge ports, like an add in filter, or is this fine condensation of no significant problem to the compressor units. I know it's a fair way from discharge port back along the internal lines to the output leaf valves and piston. But just can't help thinking this condensation could in theory make its way back to the compressor valves and reciprocating assembly. I know this is a non electrical question, but would appreciate any thoughts on this potential problem. Thank for taking time to read this problem.
