Author Topic: SMD component ID help.  (Read 1445 times)
Offline DTJTopic starter
« on: September 20, 2017, 07:55:07 am »
I'm working on a small power supply charger circuit and am having trouble identifying a part.
Its a SOT23-5 package marked "28S"
(Edited - I mistakenly put SOT23-6)
The overlay designator 'U' suggests its an IC.
Pin2 goes to ground.
Pin3 is to the battery (could be either charge or discharge).
I can't work out what it is. Any ideas?
« Last Edit: September 20, 2017, 10:50:36 am by DTJ »
Online amyk
Re: SMD component ID help.
« Reply #1 on: September 20, 2017, 10:10:21 am »
You mention SOT23-5 and SOT23-6, but I see only 5 pins.
How many does it really have?
It would also help to trace out where the other 3 pins go.
Edit: Might be TPD4E002DRLR (image in link attached for future reference.)
« Last Edit: September 20, 2017, 10:19:53 am by amyk »
« Reply #2 on: September 20, 2017, 10:56:28 am »
Thanks amyk.
It certainly looks like it is a TPD4E002DRLR.
The marking is identical.
(I had mistakenly put SOT23-6 rather than SOT23-5).
I'm not entirely sure how the TPD4E002DRLR which is a quad TVS diode array fits in the circuit - as I trace it further I guess I will find out.
By the way how did you find that information? I was lost.
Cheers!
Offline scuzzyTerminator
« Reply #3 on: September 23, 2017, 10:06:05 am »
WOOPS: this is a 4-lead SC82 device.
Topmark seems to match the SII S-1335D26-N4T2U3 2.6V LDO - HIGH RIPPLE-REJECTION SOFT-START FUNCTION CMOS VOLTAGE REGULATOR.
Datasheet: http://datasheet.sii-ic.com/en/voltage_regulator/S1335_E.pdf
« Last Edit: September 23, 2017, 10:18:02 am by scuzzyTerminator »
« Reply #4 on: September 23, 2017, 12:06:24 pm »
I've traced out more of the circuit. I'mpretty certain its a  TPD4E002DRLR.
Thanks for your help guys.
