Author Topic: Connecting different grounds in mixed analog and digital circuit  (Read 22908 times)
Offline prasimixTopic starter
  • Country: hr
    • EEZ
I'm currently working on redesign of post-regulator PCB where both analog and digital section exists. I'd like to see this time how to properly connect different grounds to ensure minimum measurement error or at least to have a error offset value that can be easily correct in calibration process. Please find below simplified circuit where I put on the same place various paths from both analog and digital side.
We have here the following: PGND comes from pre-regulator connector (X3) and that signal will be main ground plane on bottom side of the PCB and it's used for supplying analog section. DGND represents another ground plane which will be an "island" in main ground plane (PGND) and will cover area where digital devices resides (ADC, DAC, I/O expander). Post-regulator output "minus" is connected to the current sense resistor R37 which is with its another end connected with thick trace (150mil) directly to the input ground (PGND on X3). I'm using here a SH1 as a trick to avoid Eagle to automatically connect that resistor end to the main ground plane.
Two ground planes are connected together in the point close to the ADC using ferrite bead FB (or that can be a zero-ohm jumper). What is remain is a signal labeled as COM which represent reference ground point. Again it is planned to be connected closely to ADC with other ground and for that SH2 is used. On the same signal I presume that will be good to connect ADCs REFN0 which exists on ADS1120 separately from AVss input.
I put here also supply ground from voltage reference (REF5025) and DAC (DAC8552). Not so sure about that and I'd like your inputs about such proposal and comments in general about presented approach.
Many thanks in advance.
Online Kleinstein
Re: Connecting different grounds in mixed analog and digital circuit
« Reply #1 on: August 05, 2015, 03:10:03 pm »
Unless there is lots of noise comming from the digiatal part, I would not hat the ferrite bead in the DGND-PGND connection. There is no need to introduce extra differences here.
Normally its better to have one good star point, and have things like FB on the supply rails.
Things like DGND just use one common connection to the starpoint, for things that are not critical.
At the reference, DAC and other ICs, the local supply decoupling still needs to be with the GND of the chip. So if the device like the DAC has only one GND Pin, this pin has to be used for decoupling. To reduce noise coupled from the supply a FB or inductor from the +5 V rail to the cap / VCC pin can be used. In extrem cases one may need an extra electrolytic cap for decoupling, if the chips are drawing more current with LF component.
AREFN0 at the ADS1120 is part of a differential input. So connect it to GND at the reference.
An important part missing in planing GND layout are the volatge regulator for the 5 V supply and less important the supply to the OPs.
Offline T3sl4co1l
    • Seven Transistor Labs
« Reply #2 on: August 05, 2015, 07:33:42 pm »
Please don't split grounds.  If you aren't absolutely certain about what you are doing, you are absolutely better off using one, massive, continuous ground plane underneath everything (or for 2-layer construction, pours on top and bottom, stitched liberally with vias).
Alarm bells that go off immediately:
(and by that I mean, not just yellow warning flags, not just bright red error flags, but big clanging bells!)
- VREF has local bypasses, but GND isn't returned to same net!
- op-amp supplies, bypasses not shown
- DAC has no AGND. Is bypassed to PGND, but GND isn't returned to same net!
- ADC has DGND and AVSS on separate nets!
About that last case: chips with multiple ground pins are usually constructed so that, in reality, all the grounds are "shorted" internally by the substrate, or a ground metallization layer or whatever.  It doesn't look like a good short at circuit-level, because ICs aren't as conductive as copper foil.  These pins usually have < 10 ohms between each other, and I think 0.3 ohms is typical.  It's not < 0.01 ohm as you'd get from copper foil spanning the pins.  That means any current flow or noise across those grounds, appears across the IC, internally, which will likely cause problems.  Under fault conditions, it will easily destroy the IC!
No, grounding is not a netlist problem.  Not in general.  It cannot be solved through an abstract netlist assignment.  It is spacial, and can only be controlled by placement of devices.  Learn the nature of "path of least resistance" and "path of least impedance", and arrange functional blocks so that they don't have intersecting current paths.  When you do this, and follow logical practice, it makes very little difference if the ground plane is slotted or not (because you will never have signals crossing the slot), and you will never have to worry about splitting grounds around analog signals (because it's a dumb idea in the first place; thing is, one must know why, and all those appnotes that suggest it... usually don't know why!).
Seven Transistor Labs, LLC
Offline Jeroen3
  • Embedded Engineer
    • jeroen3.nl
« Reply #3 on: August 06, 2015, 05:44:40 am »
Basically you want to make sure the path first reaches the cap before the via to the ground plane. Thus: chip - cap - ground, and not: gnd, chip, gnd, cap, gnd as happens a lot when you apply the top fill. You might need to play around with the Restrict layers for this.
I wouldn't put a ferrite in the ground split, instead, I would use the ferrite at the source for the ref. But I don't know how efficient that will be. However, ferrites make more sense if put in the signal path after the connector. That is where all the noise is able to enter the system.
Also, the splitting the ADC ground is not the best practice. They've developed two Vdd's for Analog and Digital, but they did not develop two GNDs, they are internally connected. You might force unnecessary noise and currents through the adc. If you're using only 1 supply, I wouldn't bother splitting the decoupling.
The Vref will need local (almost on-chip) decoupling though.
Funny how you've put 1uF's at the ADC, but not at the DAC.
At the end it stays a bit of black magic, only really understood by few.
Offline piranha32
    • random ramblings of an engineer
« Reply #4 on: August 06, 2015, 06:30:48 am »
First of all, remember that each signal line *MUST* have corresponding return ground path. Therefore the best way to route ground is to have large ground plane. If you must achieve 24 bit precission, and really have to split grounds, make them connect at the points where the analog and digital signals meet. In your case these would be A/D and D/A converters, however with common Vref it will be difficult (if possible) to split the ground in a way which guarantees good separation without loops. One of my "to go" resources when it comes to EMC issues is the website of Henry Ott Consultants. Here is what they have to say about ground planes: partition the design, but do not split the ground plane (http://www.hottconsultants.com/techtips/split-gnd-plane.html). TI recommends to start with split grounds, route all signals over corresponding ground planes, and in the final step remove the split: http://www.ti.com/lit/ml/slyp167/slyp167.pdf
Your circuit looks simple enough to route all signals on one side. If you care about signal integrity, spend a dollar or two more and order double sided PCB with solid ground plane on the bottom, and connect all ground leads directly to the bottom side using track as short as possible.
« Last Edit: August 06, 2015, 06:32:40 am by piranha32 »
  • Country: hr
    • EEZ
« Reply #5 on: August 06, 2015, 10:38:41 am »
Many thanks to all that post so many useful comments and references. Maybe to start with a sentence found in Henry Ott's article recommended by piranha32:
A PCB with a single ground plane,partitioned into analog and digital sections,and discipline in routing the signals can usually solve an otherwise difficult layout problem, without creating the additional problems caused by a split ground plane.
There are two useful keywords: partitioning and discipline. Actually in previous revision of this PCB I followed routing discipline 100%: that no analog traces cross digital plane and vice versa. I'll continue with such practice. I didn't aware of partitioning but it's connected to mentioned discipline, it seems that at the end when everything is routed properly it's question of merging two planes into single one. But, it seems that there is still some exception from above mentioned rule of single plane (thanks T3sl4co1l to highlight that at the very beginning!). Henry continue saying:
The use of a single solid ground plane properly partitioned and routed (as discussed above) is usually adequate for most low to moderate resolution A/D converters (8, 10, or 12 bit). For higher resolution systems (14 bits and up) even more ground noise voltage isolation may be required for adequate performance. These converters have resolution voltages in the tens of  microvolts, or less, level. In this case you might want to divide your board into separate isolated analog and digital ground plane regions, each solidly connected to the digital ground plane under each of the A/D converters...
Few technical details from previous layout that address some of your comments:
  • A double layer PCB is used
  • All supplies comes from nearby pre-regulator PCB: +5V is supplied from LP2951 while +/-15V comes from another LP2951 and LM337L
  • ADC's Dgnd and AVss are on separate nets but that DGND and PGND are connected just next to ADC's Dgnd and AVss to ensure low impedance path
  • All op-amps are decoupled with 100nF against +15V and -15V power rails.
I'm understand that it is hard to discuss such complex topic without presenting details about PCB layout. I'd like to post it soon at least general idea about ground plane(s) and positioning of presented analog and digital devices with power traces. Before that I'll be free to post another version of schematic that take into account some of your suggestions. I planned to "strengthen" decoupling of current sense monitor (it could be OP27 or OPA227). Currently it works fine with only 100nF. SH2 and SH3 remains to have more control of grounding while (manual) placement and routing is performed.
  • Country: hr
    • EEZ
« Reply #6 on: August 06, 2015, 10:44:17 am »
I forgot to include this detail in the previous post. That possibly will require adding another "SH" in the schematic or moving existing SH2 from DGND to PGND.
Online Kleinstein
« Reply #7 on: August 07, 2015, 10:04:25 am »
A well planed ground is important for 4 purposes:
- keeping HF emissions down
- matched impedance lines
- reducing HF coupling between circuit parts.
- avoid LF / DC coupling to sensitive lines.
Here it is likely more about the last two, especially the last.
When it comes to DC and LF errors the best scheme is usually a star ground. The single solid ground plane is often the best when it come th high frequency noise an emissions.  The version with seperated ground planes is a try to get the best of both, but it's difficult to make it right.
May suggestiong would using some kind of ground plane for the digital part (not shown in diagramms) and a star GND scheme for the rest. Form the central GND point there would be connections for:
- the supply (5V, +-15) from regulators
- the high current supply  (if not allready connected at preregulator)
- the digital part
- the anlog signal GND, possibly more than one
- the anlog supply to circuit / decoupling
For drawing one might have the jumpers at the central GND point and thus different name for the nets.
In this context the DAC and also the ADC should be treated as analog parts. So GND at the DAC should not be DGND.  The Ref to the ADC is differential, so no need to go though the star point, but connect directly to the reference.
  • Country: hr
    • EEZ
« Reply #8 on: August 11, 2015, 08:25:46 am »
Hi everyone, here is how PCB layout currently looks like:
You can see on the picture digital section (cyan) which is designed with partitioning in mind so no analog line is crossing that area. Voltage reference is closed to digital section but again, Vref output is routed "around" and connected to DAC and ADC. I also marked with white circles three grounds that is now connected via ground plane and not using separate net connected in single point with the ground plane. This is something that I didn't have in previous version of PCB and wondering if I have to proceed with that or not. If I reverse that to separate net that will be closer to star ground that Kleinstein suggested for the analog part. Result of deploying strictly star ground for the analog part on this PCB with only two layers possibly will results with heavily fragmentation of the current ground plane. It that case maybe we could talk about ground plane but in lower area (around digital section) and the rest to do with star ground. Both of them will be connected then on light green point (input connector) and that looks effectively to me as two grounds.
Anyway bottom layer currently looks like this:
Digital power line is marked in the following picture. Voltage reference is supplied from the same line. I don't know if that is optimal. Another possibility is to draw power from +15V and use dedicated LDO to step-down to +5V for that purpose.
Analog power lines are visible on the following picture:
Thanks in advance for all your further comments and suggestions.
Online Kleinstein
« Reply #9 on: August 11, 2015, 10:18:56 am »
The analog part does not need a ground plane - a ground plane is good for HF signals, but not LF µV signals.
A ground plane might be a good idea to reduce EMI from the µC part or other high frequency digital part. The ADC and DAC usually do not see much data trafic - so even they can live without GND plane. In ADC/DAC area, the current layout does not have a GND plane, that deserves this name.
There are two more week points:
There is no decoupling of the input side of the high current supply - linear regulators often need these to work stable.
The ground line to the shunt and the positive output current through the transistors form a relatively large loop this effectively adds quite some inductance (about 100nH) - too much for a fast regulator.
  • Country: hr
    • EEZ
« Reply #10 on: August 11, 2015, 10:46:11 am »
Do you mean that current plane beneath digital section is too much fragmented to deserve name ground plane?
How to make such decoupling? I didn't notice yet any instability with existing PCB which is very similar to this one.
True. It predicts then also slow response with existing PCB that I probably can measure. How to check that? Perhaps with load transient testing?
Online Kleinstein
« Reply #11 on: August 11, 2015, 06:19:42 pm »
The "ground plane" under the ADC is to fragmented to be called a ground plane. It's more like using ground poor to get ground to all the points, without giving much thought to GND. Anyway the ADC/DAC does not absolutely needs a ground plane, unless you control it via a very high slew rate signal or do something like dithering.  Something like a busy µC controlling als graphic LCD or USB 2.0 Interface is something that should have one.
The large Loop adds something like 100 nH (maybe a little more), not having a capacitor (or two) at the input side of the high current supply adds the inductance of the external wiring. Having a cap on baord would use the wire inductance as extra HF filtering (though with  some emissions) instead of having it on the down side. It would be a good Idea to have something like 1 µF ceramic and something like a 100 µF of low ESR on board, close to the final regulator.
Its similar the the simple 3 pin chips llike 7805 - they also like to have a cap at the input, close to the chip and not on an extra baord.
How bad the extra inductance is, depends on the regulator - the faster (and thus lower impedance) the more critical. Extra inductance can also eat away reserves for critical loads and may be how low the ESR of the output capacitor may be.
Offline T3sl4co1l
« Reply #12 on: August 11, 2015, 08:07:15 pm »
I would have to take quite some time to figure out where everything is; this also appears to be far more than the schematics posted above so you need to provide a complete one of those, too.
There is never any reason to remove ground pour.  If anything, add more.  You have many resistors, etc. that have short stubs to a via: those can be removed when a full top-side pour is used.  Or better yet, the vias can be moved around (possibly more added, even) for better stitching of both top and bottom grounds.
If digital is one small corner, then I don't see that it should be any concern with regards to the rest of the circuit.  The reference being down there might perhaps be subject to noise, but if it's only being used by the ADC/DAC, it belongs there.
I would be concerned about possible ground loops.  If you have power (+/-) and load (+/-) from connectors on opposite sides, you can have ground loop currents between those connectors, which generates a voltage drop across your board (which will be particularly important, because your bottom pour is sliced vertically by several traces, which are not stitched over).
Microvolt, low bandwidth circuits are much more susceptible to high frequency noise, because small rectification effects result in much more important errors.  This is also an excellent reason to sanitize all inputs, as well as possible, filtering out frequencies that you don't need to consider.
  • Country: hr
    • EEZ
« Reply #13 on: August 12, 2015, 08:24:49 am »
Hm, ground plane is fragmented to some extend under I/O expander not ADC nor DAC. Please find below their position on the PCB with bottom layer visible. There is only one diagonal trace that goes beneath ADC that I didn't succeed to route on the top player.
I also added another 1u decoupling capacitor close to the input power connector. I also put back a 22u elco that is planned to be mounted on the chassis output binding posts.
  • Country: hr
    • EEZ
« Reply #14 on: August 12, 2015, 08:28:58 am »
Please find in attachment the complete schematic. I tried to avoid that for sake in simplicity at the beginning.
I'll try to make few another variants to explore both yours (as much as possible ground on the both side) and Kleinstein approach (star ground for the analog section).
Online Kleinstein
« Reply #15 on: August 12, 2015, 10:48:11 am »
I don't think the digital/ ADC/DAC part will be a problem - it's not perfect, especially form EMI perspective, but should work.
With the analog part, I see one problem in the circuit with the 22 µF output capacitor going to PGND. Normally the output capacitors should be toward the neg. output - thus at the other side of the shunt. The shunt helps the compound outputstage to be stable as it allways has the shunt, and no low ESR capacitance to GND. Its very unsual to need a cap to the GND before the shunt.
Having the cap before the shunt also makes it more effective to provide a low impedance output at high frequencies.
The current layout for the 22 µF an 470 nF/1 Ohm is also a problem: The GND currenc couples somewhere to the "GND plane" used for the volatge regulator - so it can interfere with regulation and worst case cause instability. With a plane, especially with some cuts, its very hard to predict what happens.
The large high current loop over the upper analog part will also inductively coulple to the ground plane: very hard to predict what happens - instability is possible, though not likely. So it would be really better to have the connectors rather close to the upper end, and the shunt close to the output stage. Even the output connector would be better Out+ Out- Sense+ - .
Though this is only a DC supply, layout should really minimize inductance for low impedance parts, as at 150 kHz a 100 nH inductance has allready an impedance of 1 Ohm and thus is  important for a low impedance output.
Offline T3sl4co1l
« Reply #16 on: August 12, 2015, 11:52:04 am »
FYI, Q4 gate is coming out the wrong side (note on Q1, it's drawn exiting from the source side).  Also, BSS84 would be more traditional there, though it won't make any difference if you don't mind the extra capacity of the IRLML2246.
If you want a more accurate near-zero threshold for IC4, you can replace R53 with a pair of resistors to GND.  This anchors the middle of the divider (indeed, splits it into two separate dividers), so that ratio differences in R50/R55 have less effect.
Also, the output resistors as chosen (R48, R49, R54, R56) are such that D12, D13 don't do anything.  The diodes might be relevant if the supplies come up at different rates (though, within ratings, the MOSFETs will never be in danger).  Or if you want to make use of them, it would be perfectly fine to reduce the resistor ratios, so that the diodes become forward biased while the comparators are on.  Really doesn't matter, it's very mildly redundant.  :-//  (I guess what I'm feeling, philosophically, is: if you have the choice between two nearly equivalent options, you must be near -- but not on -- a local minima; this is a sign that you perhaps should rethink the thing, until you find an even better local (perhaps even global) minima.  At least, when it's something that's actually worth the work.)
The voltage compensation (around IC1) seems odd.  There's a mess of lead-lag compensation (C4-C7, C9, C10), which seems to suggest you're trying to beat causality.  Which is impossible, of course.  A resistor in series with C8 would help (some pole-zero action, presumably to cancel a different pole, maybe that due to Q1's gate capacitance?), and probably slowing down the whole thing so it's not so much on the knife-edge of stability.
It also wouldn't hurt to have some raw C-to-ground on those feedback nodes, just to take the edge off.
Which segues into the other filter thing: the shunt sense IC3 should have some filtering on its inputs.  This is a bipolar op-amp, at very small signal levels, so it will be doubly important to keep HF noise (anything over perhaps 500kHz) well away from it.  R35, R38 are also rather low values, which are something of a fault hazard to IC3 -- short circuit current through the shunt can deliver quite a bit of current into the IC's input protection diodes.  I'd suggest >100 ohms, perhaps split in half (2 x 51 ohm each?) with a 4.7nF to ground (in the middle) for filtering.
IC1B should also have some filtering, for similar reasons: suppose you have a heavy, nasty switching load connected to this thing (maybe it's an unfiltered DC-DC converter drawing nasty current spikes, or a high voltage generator spewing out common mode interference).  That noise goes straight into your op-amps, which respond asymmetrically to RF inputs, resulting in shifted bias points and DC error.  Now, TL071/2 is a FET amp, which is less susceptible to interference, but I'd still add a 1MHz or so LPF to be sure.
BTW, you might swap IC2 for 1/2 TL072, just to save a BOM item.  The extra half can simply be grounded (+in = out, -in = GND).
Going back to IC1 and IC2, it seems rather odd to use +/-15V supplies, yet use only about the -2 to 0V range.  You should use only as much as needed, so the outputs don't have to slew so far when they go into the linear range.  This reduces integrator windup, which is a significant limitation on the speed of this type of control circuit.  Simple solution is to increase R24 and/or R18 dramatically, so the gain is lower and the useful op-amp range is wider.
Alternately, you could rewrite much of the circuit to use, say, +/-5V supplies (which would eliminate one supply), and use a R2R type amp like TLV2372.
ZD2 seems kind of out of place.  I don't like to see zener diodes chained in series with things, used as afterthoughts for burning voltage; it's a lazy method that often leads to problems arising from side effects.  I'd just as well clamp Q6 collector to ground with another BAS316, which seems to be fine as it's already current limited.  Also won't need D2, as D3 prevents backflow from anything else (Q2 and stuff are always below Q1 source, so aren't going to turn it on, ever).
The Q4 pulldown stuff seems odd (it's like Q1 and Q4 act as a complementary source follower pair), but I guess it's really only being used as a turn-off discharge.  Beware that it won't operate very happily if you were charging a battery pack then hit the "disable" switch!  (That said, 50V maximum and ~0.3A limit suggests a modest 16W maximum dissipation, which is fine for a TO-220 MOSFET like that.  As long as you have the load current displayed, the user will be able to see their battery charge being pissed away, too. :) )
Note that Q5 can beat the shit out of Q1 gate (in the turning-on direction), but nothing is there to discharge it (just measly little R3).  So you'll get the weird situation that, if it's on the verge of oscillation, it's able to rise much more quickly than it falls, and this can lead to weird load- or state-dependent compensation, and possibly chaotic behavior.  A more symmetrical driver would clean that up, and also raise the cutoff frequency of that node, easing compensation for the gain stage (i.e., Q9 and related parts) and error amps.
Note that Q5 doesn't have a nearby bypass cap, which may make things ugly for that bias supply (I don't know what's plugged into it, a board-to-board or a cable or who knows).
Anyway, on to the PCB:
As mentioned, you've got tons of slots going vertically along the bottom ground pour, so all those traces crossing them on top (Q10, R27; and by extension, the power going up to IC1 -- note that the PSRR of an op-amp is more dominant than RF susceptibility!), as well as extending downward until those loops close up (so this includes injecting noise into C11-C12-C14 and IC3).
The power circuit makes a grand loop, from X1 around Q1-R1 down to X2, then back through R37, over split ground.  If this circuit is exposed to ground loop current, it will feel every little bit of it in this loop here.  The voltage sense amp is right there, which kind of sucks.  Like I said, it's somewhat less sensitive, but it's still not desirable for accuracy.
Ideally, all the grounds (especially on connectors) should all be joined together, as closely as possible, thus minimizing ground loop areas, and keeping any ground loop currents away from your main circuit.  This would require moving X1, X2 and R37 near each other, perhaps making the return path above Q1, Q4 (they could be changed to horizontal orientation, parallel to the board, installed on the bottom side but facing up, perhaps?), and moving the connectors somewhere up near a corner, or along the top edge.
I'm guessing the rest of the circuit isn't a big deal.  X3 has some grounds, which might be worth looking out for (minimize possible ground loop areas!).  I'm hardly concerned about SPI and digital; those are hiding in the corner, well away from the analog parts.
But you should follow much the same idea, for the analog part as well: so the small-signal parts (op-amps and all) are isolated in their own group, away from the power path (Q1, Q4 and etc.), to keep them out of the way of stray currents and such.
And, again: top side pour, and lots of stitching!  For example, stitching over the slots in the ground pour (formed by the supply traces coming off X3 and running vertically for most of the board) just about eliminates that concern, so that the R37 path can be almost as good as the most suitable alternative (curving back above Q1, Q4).  But avoiding signal and power trace crossings altogether is even better, so try for that first.
HTH,
  • Country: hr
    • EEZ
« Reply #17 on: August 12, 2015, 02:50:49 pm »
Huh, you're right. It's wrong placed in schematic and as I said it was planned to be connected over binding posts that means in parallel with Out+ and Out-. I'll correct that in next revision.
Good point, thanks ;) That swap will be visible also in next revision.
  • Country: hr
    • EEZ
« Reply #18 on: August 12, 2015, 03:15:58 pm »
A massive thanks Tim for such review  :-+. I'll try to comment as much as possible soon. But before that I'd like to hear what you think about merging X1 and X2 together. That should improve electrical characteristics since op-amp bias supply will not require such long vertical traces. Main return (power ground) is anyway planned to be on X1 connector only.
The post-regulator is directly connected to the pre-regulator PCB with that two connectors. Using one will somehow weaken mechanical strength but not so much since main mean of fixing both PCBs is using four screws on the corners.
Please let me know if 1uf ceramic is enough here? This bias comes from rectified and filtered by 470uF 48VAC main power.
Online Kleinstein
« Reply #19 on: August 12, 2015, 07:05:16 pm »
For Q5 1 µF is plenty decoupling. Even 100 nF should be enough if the line is not very long.
I think there are two problems:
First there still seem to be a few (hopefully minor) weak spots in the circuit. Some of this is more than changing values.
And than the layout is not good.
Usually it's best to fix the circuit first, as this might give some changes (e.g. resistor in series to C8 is a good idea) - even if only minor.
I also agree that the compensation at the input side of the differental amplifier needs a makeover: Because of the differential stage its essenstally double. Still I think it can be simpler: usually one cap per side might be enough - mainly for the switchover from DC feedback from the Sense inputs to high frequency feedback mainly from the outputs. This is needed to prevent oscillations if power and sense lines are not closely coupled. There is essentially no other way to prevent oscillations with poor external wiring to a capacitive load. Even than a very poor configuration of the sense wires will oscillate - but that is close to using transformers.
A llittle higher impedance at the current sense amplifier is a good idea to make it survive surges and may be even a burned / loose shunt. Some filtering is OK, but not to much, as this makes regulation more difficult. The most important point for filtering is a low ESR/ESL cap directly at the input therminals and small extra caps to the case.
For the layout, its usually best to start with the critical connetions. With this circuit this is first the main current path and the return ground. The next in importance is ground. It is Ok to show only partial layouts e.g. with just the critical part -  here groundfill makes it hard to follow, having true lines for GND is clearer, even if later ground fill is used.
Usually using ground fill with a plane cut into small pieces is not helping with EMI or cross coupling. So either have a closed ground plane that deserves the name (high currents still need to be handelt separately) or have separate GND lines and GND fill or lager GND areas mainly for thermal reasons. For the signal quality such partial fills usually don't help.
Offline T3sl4co1l
« Reply #20 on: August 13, 2015, 02:04:06 am »
How long is the connector/cable route expected to be?  Figure 10nH/cm times the length of traces/connectors/cables between the bypass cap and the main bulk cap.  The ideal ESR is sqrt(Lstray / Cbyp).  If this ESR is present in the bulk cap, you're golden.  If not, you might want a series resistor for Cbyp, or add a lossy bulk cap across it (Cbulk >= 2.5 Cbyp) with that ESR.
Merging the connectors would be helpful; this goes under my suggestion of putting them nearby.
  • Country: hr
    • EEZ
« Reply #21 on: August 13, 2015, 08:33:04 am »
I finished a part of my homework initiated by comments from Kleinstein and Tim (T3sl4co1l). The first sheet (in attachment) from schematic is now includes the following changes:
1. Decoupling capactitor C4 is added
2. IC2 is changed to half of TL072 to reduce BOM items and price (I found that TL072 is cheaper then TL071).
3. Input section of IC3 is now redesigned. I have to use two resistors to get 4.080K required to get gain ov 40V/V in combination with 102R (2x51R).
I run by mistake renumbering so please note that items numbers is now different.
I finished the first remake of PCB layout which do not include merging of two input connectors (X1 and X3). I deliberately limit ground plane to bottom half of the PCB to have a clear picture of ground net in the upper part. I didn't experiment yet with adding ground plane on the top layer. Three solid area on the top layers represents heatsinks for Q4, Q6 and Q8. You can also see that I remove huge loop by moving return trace (Out-) up, next to Out+ (each traces are ~90mm long). Here is how both layers looks with ground plane cut to half:
Bottom layer with ground plane cut to half:
I spent some time to color code important paths on the bottom layer:
Now if we extend the ground plane to cover complete bottom layer again it looks like this:
It looks pretty good to me and the question is with which bottom layer layout to proceed?
In this moment I'd like to address multiple warnings about possible instability of the circuit with asking the following question again: what types of test cases can be used to sport such instability? I made until now a lots for testing with various combiantion of set voltage and current to cover full range (50V, 3A), going back and forward between CV and CC mode and made that with various loads such as different power resistors, halogen lamps, DC motor, capacitors and inductors.
« Last Edit: August 13, 2015, 08:40:14 am by prasimix »
  • Country: hr
    • EEZ
« Reply #22 on: August 13, 2015, 08:43:04 am »
I have one question about using multiple vias to connect one leg of current sense resistor (R39) to bottom layer: does 8 vias is sufficient for 3A current (possibly up to 5A)?
I am thinking about remove protection mask from them to make it solderable and fill it additionally using soldering iron.
« Last Edit: August 13, 2015, 08:45:04 am by prasimix »
Online Kleinstein
« Reply #23 on: August 13, 2015, 09:22:43 am »
The layout looks much better. How much current the vias can stand depends on the manufacturer. They should have numbers. having the option to solder is a good idea, just in case.
For stability testing, the critical tests for voltage regulation are:
Sinulations should include realistic parasitic inductance for the shunt / GND path (here maybe 50 nH).
The voltage set to do the test should not make a difference with this circuit. Usually the extremes are worst.
1) just a current souce (Spice part), as load. DC current near 0 + AC Current -> effectively look at output impedance
2) same as before, but higher current (e.g. 2/3 of max.)
    The output impedance should not have any phase shift larger than +-180 deg.
    For the range around 1 MHz, adjustung the output capacitor and possible series resistor might help
This 2 test can test most cases of instability. Idleally one wants a low impedance and enough distance to the +-180 deg. bounds, at least where impedance is not very low. So getting very close (e.g. 175 deg.) at something like 100 Hz is normal, but the 100 kHz - 10 MHz range should have much more reserve (e.g. > 30 deg).  However there may still be poor regulation - especially if one only looks to frequency domain and trys to defeet causality by adding more and more RC combinations.
So the final test is in time domain:
3) Testload of pure cap + current source with steps of something line 10 mA / 1 A and back with something like 1 µs rise/fall
    Caps at something like 10µF , 100µF, 1000µF and 10000µF with low or 0 ESR and possible realistic values.
    Quite some ringing at 10 mF (or more)  and 0 ESR is more or less normal. Just a few mohms of ESR
Offline T3sl4co1l
« Reply #24 on: August 13, 2015, 11:18:55 am »
Ground plane looks good.  Some routing tips:
Observe the negative space, which is filled by the pour.  Try to have it wrap around every trace (or grouping of traces) if possible.  Examples (pour has been colored cyan for clarity):
On the bottom left, these are a good example.  The ground fill keeps the traces isolated, and somewhat reduces their impedance / inductance (if this is useful).  Downside: takes up a lot of space, so it's not so handy to do for a bunch of signals at a time (say, a parallel data bus?).
Here's a tiny hiccup, of sorts.  If the via can be moved, allowing the pour to close around the pads, you might as well.  The loop in this case isn't very big (the peninsula is only a cm or two long), so it won't be "flapping around" with much inductance, certainly not enough to notice in a circuit like this.  These kinds of details get more important in switching or precision or RF, so it's a practice-makes-perfect sort of thing to be prepared when/if you do work on such circuits.
Where you have a bunch of traces, it can be handy to group them, or hug along routes -- but mind that, in doing so, you trap and isolate the pour where the traces gather.  If there isn't much advantage to gathering traces, say over a short run, you might as well give more clearance to everything, so the ground can fill.  A possible re-route is shown in red.
Remember that every trace is cutting a slot into the pour.  Around this trace, there may be slightly different voltages on the left/outside and right/inside bits of pour.  You could fix this with a hack, by adding a two vias and a short trace to jumper over this splitting trace, or better still, stitch it with top side pour wherever possible.
