Electronics => Projects, Designs, and Technical Stuff => Topic started by: richard1991 on May 10, 2017, 10:59:57 am
Hi. I've used veroboard pins on a veroboard so I can connect flying leads or jumper wires. I went and ordered some breadboard jumper wires with female sockets on the end, but they do not fit the 1mm diameter veroboard pins. So, I need some jumper leads with female sockets that fit the 1mm diameter pins.
Is anyone here buying such a product, or identified a supplier? I've not turned up anything so far. Thanks.
See https://www.eevblog.com/forum/projects/please-identify-this-connector/ (https://www.eevblog.com/forum/projects/please-identify-this-connector/)
In there, I have pix and a manufacturer link, might be what you're looking for.
