Author Topic: Connecting Parallel Transformer Primaries with Faston Connectors  (Read 1589 times)
Offline grbkTopic starter
I'm wiring up a mains transformer inside a metal chassis and want to make sure I'm following best practices for safety & reliability. This is for a personal project, nothing commercial, and low power, but I do want to know what the "best" way to do this is. Ideally any solution would pass a UL certification, etc.
The transformer has two primaries, and I'm on 120V mains, so I'm connecting them in parallel. I'm using crimped Faston/quick connect terminals to make the connections. I have line/neutral from the IEC inlet to a front panel power DPST switch, with faston connectors on the inlet and the switch. But now I have two transformer primary wires to connect to each tab on the switch. How do I connect two transformer primaries to a single tab, preferably with crimped faston connectors?
To be clear, I understand in theory how to connect the primaries in parallel (I know which wires need to be connected together). My question is how to make the physical connections. I see several possibilities, but I don't love any of them and I'm hoping I'm missing an obvious solution:
  • Ditch the crimped terminals and solder the wires directly. I worry about the reliability of the soldered connections to freehanging wires, but mostly this is not an option because I specifically want to be able to swap out the transformer.
  • Crimp both primary leads into a single faston connector -- this seems dubious.
  • Crimp both primary leads into one side of a butt splice. Crimp the other side of the splice onto a single wire, which then gets crimped into a faston connector, which connects to the switch. For some reason this seems slightly better than 2) above, but it's basically the same in that I'm still crimping two wires into a single terminal.
  • There are all sorts of freehanging 2-to-1 wire splice options out there. For some reason these still seem a bit amateur/how-ya-doin', but maybe I'm being unreasonable?
  • make the connections with a chassis mounted terminal block and spade terminals
  • make the connections with a PCB -- overkill to design a PCB and get it fabbed, plus now I have to think about PCB creepage distances.
  • Edit: I suppose I could use a 220V/120V selector switch. That seems superfluous for a device that will only be used by me.
  • "Piggyback" and two-to-one faston terminals exist, but most of them are uninsulated. I'm using an earthed metal chassis, so uninsulated is not the end of the world, but I'd still prefer an insulated solution. Still, this might be my best option.
Are there any better solutions that I am missing?
Are there any resources (books, articles, etc.) that are helpful for this kind of mains chassis wiring that anyone could point me to? I've found some information in Art of Electronics and in Doug Self's Power Amplifier book, but neither are as comprehensive as I'd like.
One further question: I've seen several recommendations to put an X2 capacitor across the power switch. Is this best practice? How would one make the connections? Soldering it would be easy, but that seems incompatible with using Faston terminals.
Thanks for any advice.
« Last Edit: March 09, 2019, 05:05:12 pm by grbk »
Offline Gregg
Re: Connecting Parallel Transformer Primaries with Faston Connectors
« Reply #1 on: March 09, 2019, 05:32:40 pm »
There are plenty of DIN rail mount terminal blocks that would suit your purposes.  That is if you have room in your enclosure.
« Reply #2 on: March 09, 2019, 06:42:48 pm »
Thanks for the suggestion. I knew very little about these so I just did some reading. They seem very useful. I think they will be too big for this project, and perhaps overkill for the limited number of connections I'm making, but I'll keep them in mind for future projects.
Offline helius
« Reply #3 on: March 09, 2019, 06:59:04 pm »
You could also use Wago 221 or 222 lever-lock connectors, either free-hanging or mounted to a rail using Wago system carriers.
Offline Benta
« Reply #4 on: March 09, 2019, 08:48:16 pm »
The "piggyback" solution is the right one, with heat-shrink insulation if needed.
Offline 2N3055
  • Country: hr
« Reply #5 on: March 09, 2019, 09:04:07 pm »
I second the Wago...
Dr. Richard W. Hamming
« Reply #6 on: March 09, 2019, 09:18:57 pm »
These look pretty nice; I'll keep them in mind. Not available at Digikey/Mouser which is a bit of a drag, but Newark does carry them. Thanks for the suggestion.
This is what I'm leaning towards, plus I found some from Molex that are fully insulated. Thanks for the confirmation that I'm on the right track :)
Does anyone have suggestions on reading material or other resources for this sort of chassis wiring?
Offline rdl
« Reply #7 on: March 09, 2019, 10:04:56 pm »
Since this is a one-off project, I vote for #2. Twist and crimp the two wires together in the same connector.
As a matter of fact, I believe I did nearly the same thing for a power supply I built over 10 years ago. I'd have to open it up and look to be sure though.
Offline David Hess
  • DavidH
« Reply #8 on: March 10, 2019, 04:57:36 pm »
If you do not want to solder, then I would use #2 and crimp two leads into a single connector maintaining an insulated connection.  I do not understand why you think this is dubious.
Offline Gregg
« Reply #9 on: March 10, 2019, 06:05:17 pm »
Another solution might be to use ring terminals with a small machine screw and cover the junction with heat shrink. Then the transformer can be removed at a later date and still have usable terminals attached.
Ring terminals back to back nest quite nicely especially uninsulated ones; you often can remove the insulation from the ones with the colored plastic sleeves.
For solid wire like transformer magnet wire, the ring terminal can be lightly crimped to keep it in place and soldered.
I have often put two stranded wires into a single crimp by stripping long, fanning out the strands, stacking the fanned ends on top of each other and twisting them together to form a well-mixed array of strands then cutting the bundle to length before stuffing it into the crimp sleeve.
« Reply #10 on: March 11, 2019, 12:18:28 am »
I appreciate the input; this is probably the easiest option and I guess it isn't as sketchy as I think. My reluctance comes from a lot of time spent debugging poorly constructed race car wiring harnesses, and after that experience I get nervous with anything other than a single-conductor-per-crimp (soldered connections and substandard tooling give me nightmares!).
But after receiving these replies, I spent some time re-reading NASA workmanship standards (the gold standard as far as I'm concerned) and crimping multiple wires into a single terminal is explicitly allowed (my memory was the opposite). Given that my application is vastly less demanding than aerospace or even motorsport, I agree my concern's probably misplaced :).
(snip)
I've done this before and it worked quite well.
