Author Topic: Lab Power Supply - The Lost Current  (Read 21709 times)
Offline xavier60
Re: Lab Power Supply - The Lost Current
« Reply #125 on: October 29, 2018, 11:29:32 pm »
I did some testing with my bench supply.
Connecting a 12v battery to the output with the correct polarity and the bench supply powered off did not cause any problem.
Connecting a 12v battery to the output with reverse polarity and the bench supply powered on caused it to current limit.
I had the CC set to 1 amp. Higher current settings would cause a much higher dissipation in the MOSFET because of the added voltage across it.
When I made the last tidied up PCB, I made provision for a BC548 plus some resistors and diodes that sense reverse polarity and clamp Gate drive. I have now added theses parts. So  now when more than 2v reverse voltage is applied to the output, the MOSFET is turned off.
I guess eventually the output capacitor will explode. I could replace it with ceramics but the capacitance varies too much with changing voltage.
« Last Edit: October 29, 2018, 11:31:35 pm by xavier60 »
HP 54645A dso, Fluke 87V dmm,  Agilent U8002A psu,  FY6600 function gen,  Brymen BM857S, HAKKO FM-204, New! HAKKO FX-971.
Offline radoczi94Topic starter
  • Country: hu
  • Electronics lover since 12y/o
« Reply #126 on: October 30, 2018, 06:12:35 pm »
Hm, interesting. I don't know what will happen to the series pass element if it is a transistor. What will hapen to the circuit if it is on, and set to a voltage lower than the battery voltage? I guess, the CV opamp pulls down the gate, the mosfet closes and nothing happens.
Offline xavier60
« Reply #127 on: October 30, 2018, 09:02:14 pm »
The CV op-amp will turn off the TIP142's. There should be no problem.
Btw, I don't understand the terms "open" and "close" with respect to transistor conduction states.
The following users thanked this post: radoczi94
  • Country: hu
« Reply #128 on: October 30, 2018, 10:20:33 pm »
Sorry, the cause is probably the lack of my english knowledge. In hungarian, we open (turning on, forward biasing) and close (turning off, reverse biasing) a transistor or a diode. Thanks for the correction, I did not knew about this, will not use again.
