I am just developing DCDC converted based on LM25145 IC from Texas instruments and I would like to know your opinion about one topic that always make me doubt, which kind of connections should I use in this modules, talking about INPUT-OUTPUT, the main idea is to have enough current capability (2Amp output 16V and around 1.6A 20V input) and also good let's say....testing capability, in order to connect easily this module to power supply, load....
I have seen different approaches:
-- Using terminal block connectors THT , I don't really like to be using the screwdriver each time I would like to connect it...
-- Using SMD big pads, and connect them with Crocodile Clips, the connection between is not the best
-- Using 2mm banana holders or post , maybe the best connection and also easy way?
Do you know if there is something like a....press fit connector but one which you could extract easily? What is your preferred connection? Solder some cables and that's all? Easy way
Thanks for your comments.
BR
