Author Topic: Connector help?  (Read 1222 times)
Offline mattbrockukTopic starter
Connector help?
« on: March 13, 2019, 07:59:42 am »
Hi
I've misplaced some cables for a piece of equipment, so hoping to make a new set up - but I'm struggling to identify the connector type used, I was hoping someone here might recognise it ...
Its 50 pin, it has 2.54mm pitch and reminds me a lot of a d-type (even with the latching ears) but the top / bottom rows aren't offset like you'd normally see with a d-type connector...
Thanks in advance
Matt.
Offline loveny
Re: Connector help?
« Reply #1 on: March 13, 2019, 08:26:30 am »
SCSI I think, I've got a piece of equipment with a 60 pin connector, never found the mating half (probably haven't looked very hard though).
Offline LapTop006
Re: Connector help?
« Reply #2 on: March 17, 2019, 05:23:47 am »
It's certainly the *style* used for SCSI-II, however those were much smaller physically.
Re: Connector help?
« Reply #3 on: March 17, 2019, 07:40:15 am »
Re: Connector help?
« Reply #4 on: March 18, 2019, 02:50:06 pm »
Thanks guys - it does look very much like that Harting - :( at being NLA
Pondering about bodging in 2.54mm male header ....
Offline Ranayna
Re: Connector help?
« Reply #5 on: March 18, 2019, 09:43:46 pm »
That is not a SCSI connector. The ones with the DSUB style plug have offset pin rows, and while i do not remember the pin count, i'm sure they also were smaller. The newer SCSI connectors have a smaller pin spacing, as is visible in the screenhot of beanflying. I think in his link the 2.54mm spacing refers to the PCB pins.
Can you tell us what that card is? Looks like an old ISA bus card. I have never seen such a connector without offset pins.
Offline jayeye
  • EE-turned-CS, security/networking/embedded-systems
Re: Connector help?
« Reply #6 on: March 23, 2019, 02:45:08 am »
Maybe if you had taken a better-framed, better-lit picture of the connector? I can't see *any* pins.
Re: Connector help?
« Reply #7 on: April 07, 2019, 04:30:28 pm »
Hi - your right its not male (pins) its female (sockets)
