Author Topic: Reverse Engineer or Datasheet Available?  (Read 1412 times)
Offline domremyTopic starter
« on: March 09, 2019, 12:22:53 pm »
Hello,
I need the data sheet for component PXE1610 which is manufactured by Ifineon. It seems almost impossible find so I wonder if anyone can reverse engineer this chip or if anyone can provide me with the datasheet?
Thanks!
Offline Rerouter
Re: Reverse Engineer or Datasheet Available?
« Reply #1 on: March 09, 2019, 12:33:44 pm »
Have you tried emailing Infineon, If the info is not public it may be behind NDA for stupid reasons,
If its something you want to build into a product, drop it, if its something your trying to repair, try emailing them first, or searching for the series name
Offline RES
« Reply #2 on: March 09, 2019, 01:22:17 pm »
FP1008L1-R150-R
OEM Design: PXE1610
Description: Asynchronous Step-Down Converter,
CPU Power for VR13 6+1 phases
« Reply #3 on: March 09, 2019, 03:10:46 pm »
Thank you for your replies.
Yes, I have tried to contact Infeon but it is behind NDA and it is a piece of equipment I want to repair.
FP1008L1-R150-R
OEM Design: PXE1610
I am sorry for such a poor question but do you mean the datasheet for FP1008L1-R150-R will be the same for the Infineon chip? Is it the same chip?
Thank you for your help
Offline tsman
« Reply #4 on: March 09, 2019, 05:11:39 pm »
If you want this reverse engineered then you're going to have to do it yourself. That series of chips was originally by a company called Primarion and there are some datasheets for other devices lurking around . There may be some equivalent Infineon branded versions as well. Look to see if there is anything in common which will help you.
FP1008L1-R150-R is a SMD inductor so I've no idea what that post is trying to say.
« Reply #5 on: March 10, 2019, 10:40:59 am »
Hello,
Thank you for your reply. I don't know how to reverse engineer unfortunately.
if someone could help me find the datasheet for the PXE1610 or help me reverse engineer I would be happy to make a donation to the site.
Offline JoeO
  • I admit to being deplorable
« Reply #6 on: March 10, 2019, 02:19:16 pm »
What is the piece of equipment you are trying to repair?
Maybe the schematic of the unit is on the web.
The day Al Gore was born there were 7,000 polar bears on Earth.
Today, only 26,000 remain.
« Reply #7 on: March 19, 2019, 05:49:25 pm »
This motherboard
SUPER MICRO SUPERO C7Z270-CG
http://www.hwbattle.com/bbs/board.php?bo_table=cpumbram&wr_id=34250&ckattempt=1
There are photos of the PXE1610 0BDN further down the page
