Hi. Can anyone identify this connector (image attached). This "appears" to contain four male pins though the connector itself appears to be female. I can see four leads on the PC board in its vicinity, though that of course doesn't guarantee the pin count. I'd like to identify this connector and especially its mate so that I can obtain one -- ideally with a ribbon or other cable already attached since it appears that dealing with those very small pins would not be easy if I had to assemble the mating connector myself. This connector is very approximately 1cm across at its widest point. The actual opening is extremely narrow vertically relative to the PC board -- I don't have a good way to measure it. Thanks very much!
