the 2.8ohm impeadance wont matter at all. pretty much anything below ~5k usually wont matter, except if you plug it into an amp with a low value resistor on the input, then it would, but in this circuit wont.
the digital pot I want it to adjust the volume so when you switch it between settings you don't have a volume change.
my biggest problem now pretty much is the current draw of the analog switches, they each draw about 80mA, and with like 20 of them it draws A LOT of current.
maybe there's something that can also switch a signal like them but without a massive current draw?
then I could make it not use a din 5 connector and instead a 9v battery perhaps, even if not it would be better that it doesn't draw that much current.
also I could use a stereo connector also to supply power BUT, then I would need to step down the voltage to 5V for the logic circuits and still have 12V for the op amps.
and that would mean 2 things, noise and heat.
oh also my plan was from the start to have presets and have them selectable by the rotary encoder, and also having the ability to set "favorite" presets with it too.
