A SiC Schottky actually has higher forward voltage drop than a normal diode, but the big deal is essentially zero reverse recovery. At the instant the mosfet turns on a normal fast recovery diode will allow current to flow backwards through itself for several tens of nanoseconds so this means at that instant the mosfet has both high voltage across it *and* high current through it so it is subject to switching stress and some amount of heating. By comparison a SiC Schottky just lets go easily and so the mosfet stays happy. The diode you have chosen will of course work, just that it and the mosfet are grinding each other’s gears behind the scenes.
If the circuit is running in discontinuous mode, that is to say, the inductor current runs out before the mosfet turns back on then no big deal. Your chosen diode will be okay. The inductor current will actually reverse a little and turn the diode off softly.
