Author Topic: connector search - like a "low profile" dsub?  (Read 1070 times)
Offline max_torqueTopic starter
    • bitdynamics
« on: May 24, 2018, 01:09:25 pm »
I could do with a connector, of about 12 ways, that is similar to a dsub, but lower profile (ie lower overall height from the pcb top surface)  It needs to have physical locking (screws, clips etc) and be relatively robust. Something like a single inline dsub.  Is there such a thing that doesn't cost the earth (ie no rarefied MIL spec unobtainium options please ;-) )
Offline ajb
Re: connector search - like a "low profile" dsub?
« Reply #1 on: May 24, 2018, 02:11:03 pm »
Shrunk Delta Ribbon (SDR) connectors?  Not sure if you can get bare plugs easily, and cable assemblies tend to be pricey on account of being made from multi twinax, but the connectors themselves otherwise meet your requirements.
Offline nfmax
« Reply #2 on: May 24, 2018, 02:31:22 pm »
How about a micro-D? A bit pricy, but generally good quality - http://uk.farnell.com/c/connectors/d-sub-connectors-components/micro-d-sub-connectors
Online SiliconWizard
« Reply #3 on: May 24, 2018, 02:55:03 pm »
You could take a look at the Harwin Gecko line:
https://www.harwin.com/connectors-hardware/gecko/
Not cheap. But great stuff.
The following users thanked this post: Wendy_Preston
    • bitdynamics
« Reply #4 on: May 24, 2018, 04:17:35 pm »
a-ha, "micro D" is the search term i was after!  That opens up a lot more options   :-+
    • bitdynamics
« Reply #5 on: May 24, 2018, 04:18:23 pm »
Next question, can i run USB through such a connector? I'd imagine so, they look relatively low loss??
Offline Gribo
« Reply #6 on: May 24, 2018, 06:11:43 pm »
You can run USB2 (480Mbps) on a micro-D connector, as long as the wires are short, and the D+ and D- are adjacent. I had a design that did just that, however the cable was very short (<30cm).
I am available for freelance work.
Offline nfmax
« Reply #7 on: May 24, 2018, 07:11:38 pm »
You can get sealed micro-D connectors as well. Long ago, I specified them for a data recording device, one specimen at least of which was able to preserve its contents after few days unintended immersion in the North Sea.
    • bitdynamics
« Reply #8 on: May 25, 2018, 12:05:29 pm »
Searching for connectors is SUCH fun!
I particularly like the way that the usual distributors make no effort to cross link any of the parts, so that to actually buy a complete connector set (ie, the plug, contacts, backshells, matching socket, contacts and backshells etc) it take the detective skills and logical reasoning of an actual genius....   |O
anyway, it look slike the 3M 102 series micro D is the answer  :-+
