Author Topic: Advice on conformal coating  (Read 1034 times)
Offline daqqTopic starter
  • Country: sk
    • My site
« on: March 08, 2019, 09:10:23 am »
Hi guys,
We will be doing a conformal coating of a PCB. The PCB contains lots of stuff, but the iffy part are several diodes in a MINIBLOC package ( similar to http://ixapps.ixys.com/datasheet/dsei2x30-04c_dsei2x31-04c_dsei2x30-06c_dsei2x31-06c.pdf ).
We can use two approaches:
 - spray/dip coat the fully assembled PCB with the diodes screwed on.
 - spray/dip coat the PCB without the diodes screwed on.
Either way we shall be masking a few parts of the PCB since there are contacts that must remain exposed either way.
I'm for dip coating the PCB without the diodes screwed in and screwing them in later. A colleague is for the other option.
What is the proper way to do this? A PCB with screw on power parts?
Thanks,
Online tszaboo
Re: Advice on conformal coating
« Reply #1 on: March 08, 2019, 11:11:59 am »
I'm 90% sure the thermal expansion of those terminals is going to break apart the conformal coating after a while.
I used these in the past, It is not even that simple to just scew it in and done.
The following users thanked this post: daqq
  • Country: sk
    • My site
« Reply #2 on: March 08, 2019, 12:58:29 pm »
Thanks for the info. The conformal coating is fairly flexible (Electrolube HPA https://www.electrolube.com/pdf/tds/044/HPA.pdf ), so cracking should not be that much of an issue.
Online tszaboo
« Reply #3 on: March 13, 2019, 01:54:26 pm »
Wait, you are not applying the coating on the screw then? Might have misunderstood that.
I would not dip the SOT227 parts into the coating in any case, since the bottom of it has to be thermally conductive to the heatsink below it.
The following users thanked this post: MattyT
  • Country: sk
    • My site
« Reply #4 on: March 16, 2019, 06:54:47 pm »
I would prefer not to. My colleague has a different opinion. My preferred option would be to mask all the PCB, coat the PCB, remove the masks and assemble the diodes.
The diodes won't be needing a heatsink at all, given that they are only used for their pulsed characteristics (the average power on them will be less than 1W (the peak pulse power will be much higher).
Online nctnico
« Reply #5 on: March 16, 2019, 07:16:56 pm »
My gut feeling says to make sure the screws are not covered with conformal coating. There is probably a spring washer under the screw and the conformal coating can keep it from doing it's job.
