Hi everyone.
I'm trying to create a project with an EM-506 GPS Module.
The problem is that I can't understand what types of connector I should use to test the GPS module (which already has a cable with a female connector) on:
.- Breadboard,
- And subsequently also on PCB;
Sorry if it's a trivial question, but even searching on the internet I'm not sure which connectors are suitable.
I also tried to consult the datasheet, but unfortunately I can't find the information I need.
Additionally, where do you recommend I buy them?
I'll add two photos so maybe you can understand better.
Thanks a lot to everyone.
